connection problem on super afr..
Old Jun 10, 2003 | 12:40 PM
Rotor Nut.
i am having trouble connecting my hks super afr. i dont know where the afr input and output is for the ecu. i found the imput but the output i am still having trouble with. anyone have an ecu check for a 88t2?
Old Jun 10, 2003 | 03:36 PM
NZConvertible's Avatar
I'm a boost creep...
Are you talking about the airflow meter? There's only one wire that sends the airflow signal to the ECU (pin 2E, green wire with a light blue stripe). You want to intercept that wire with the AFR. Cut it and solder the AFM side to the unit's input wire and the ECU side to the output wire.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
