i have a question???
Old Jun 9, 2003 | 02:51 PM
nitroracer's Avatar
Dub'N
would the MOP not being plugged in, cause me not to boost and to run hella rich?
my na-t2 is done and thats the only ploblem, i cant boost.
hit the gas and it boggs crazyly i drove it . idles good
i was told it can be a intake leak but i replaced all the hoses..
help a fella out
Old Jun 9, 2003 | 03:00 PM
Project84's Avatar
Open up! Search Warrant!
Check waste gate and blow off valves.
Old Jun 9, 2003 | 05:41 PM
NZConvertible's Avatar
I'm a boost creep...
Re: i have a question???
The OMP must be plugged in and functioning correctly or the ECU will go into limp-mode (i.e. very reduced performance).
It sounds like you haven't plugged it back in yet. Why not? You're damaging your engine running without it.
Old Jun 9, 2003 | 06:19 PM
nitroracer's Avatar
Dub'N
k i got it in. but still no boost? whats with that? i checked the codes on the ecu its 33-port air solenoid valve. what went wrong on that??? also some code i never seen before 83?.
the shop told me i needed a FCD. but i thought it would hit the max boost then cut out. im not even boosting
Old Jun 9, 2003 | 06:22 PM
Disconnect the battery to reset the ECU and clear the error codes.
Old Jun 9, 2003 | 07:12 PM
nitroracer's Avatar
Dub'N
did that and still 33 and 83
Old Jun 9, 2003 | 07:17 PM
yearrgh's Avatar
Must...scrub...parts...
Check the waste-gate actuator arm and make sure it didn't pop off the lever for the gate. Actually, it probably isn't that it wouldn't bog, it just wouldn't boost. What do you mean it bogs? Does it just refuse to accelerate, or does it accelerate then die then accelerate then die, if that's the case then you're running into fuel cut and you need a FCD.
Old Jun 10, 2003 | 12:25 AM
nitroracer's Avatar
Dub'N
once i get to 7 vac. going to 0 on the boost guage it just bogs and puffs out black smoke. im gunna order a FCD to see if that takes care of that. but if you guys dont think its that help me out.
-nick
Old Jun 10, 2003 | 12:31 AM
Scott 89t2's Avatar
SOLD THE RX-7!
what ECU are you running? what boost sensor?
Old Jun 10, 2003 | 12:36 AM
nitroracer's Avatar
Dub'N
370 ecu and 370 boost sensor
Old Jun 10, 2003 | 08:41 AM
nitroracer's Avatar
Dub'N
bump
Old Jun 10, 2003 | 09:11 AM
HAILERS's Avatar
HAILERS
On the 33, see if you have 12v on the black/white wire at the Port Air solenoid. If you do, the check the continuity of the other wire at the solenoid back to the ECU on pin 2N.
I see no code 83 in the 91 manual so theres no help there. So what is a 83 code?
If you drive the car but just keep off the boost, will the car redline? Or if keeping off the boost, will the car go 90 plus mph? As in slowly getting to 90 by easing the pedal, not stomping it?
Old Jun 10, 2003 | 11:56 AM
Scott 89t2's Avatar
SOLD THE RX-7!
well considering his air pump and emissions are removed the 33 would sound pretty normal you should have a few from that though. you are probbaly just mis reading the 83.
Old Jun 11, 2003 | 12:05 AM
nitroracer's Avatar
Dub'N
ya maybe i was miss reading the code 83.
hailers yes that is how i have to drive her. ease on the gas. anymore and bam bog
Old Jun 11, 2003 | 12:31 AM
nitroracer's Avatar
Dub'N
HAILERS -*On the 33, see if you have 12v on the black/white wire at the Port Air solenoid. If you do, the check the continuity of the other wire at the solenoid back to the ECU on pin 2N.*
what should i be looking for when i do follow this wire?
Old Jun 11, 2003 | 12:11 PM
nitroracer's Avatar
Dub'N
bonk
Old Jun 12, 2003 | 01:47 AM
nitroracer's Avatar
Dub'N
k got the FCD in and still same problem no boost. hit the gas slowly goes up in the RPMS but when i punch it no boost and puff of black smoke?
any solution plz help?
Old Jun 12, 2003 | 07:52 PM
HAILERS's Avatar
HAILERS
Forget about the port air solenoid if its been removed from the car. That's not the problem. You'll keep getting that code as long as the solenoid is not connected up, though. You might want to unscrew that solenoid from the acv and attach it to the harness to rid yourself of the code.
Lack of a omp is the real culprit. You need to address that issue.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
