Road Race Turbo Experts
Old Jun 9, 2003 | 01:02 PM
Jack's Avatar
I would like to know if any one has used a TO4B 60-1 .96 P trim Turbo. I am a Driver Ed Instructor looking to make 350 -375 RWH. I have been running the stock twins and do like the grunt coming out of a corner however want more power and reliability a single offers.
Old Jun 9, 2003 | 01:33 PM
eViLRotor's Avatar
Brother of the Rotary
Actually, that is the EXACT turbo my friend IAN purchased to run the road course at Shannonville..
So, I think its a good choice...
Old Jun 9, 2003 | 02:28 PM
Jack's Avatar
evilrotor
How much lag or at what rpm are you 12psi, did you dyno the car and how much lagi is there coming out of a corner.
Thanks much........
Old Jun 9, 2003 | 02:38 PM
eViLRotor's Avatar
Actually, I don't have that turbo.
Its my friend that does.
Turbonetics recommended that exact setup for road-course racing. Ian wanted very quick spool and great low-end for coming out of corners.
I run a slightly larger KKK...
Unfortunately, he hasn't installed it yet, so I can't give you any hard data
Old Jun 9, 2003 | 05:09 PM
CCarlisi's Avatar
Rebreaking things
jack didn't find my reply useful so I'm removing it
Old Jun 9, 2003 | 05:29 PM
80-CU.IN.T's Avatar
Originally posted by CCarlisi
Jack, you may want to rephrase. "lag coming out of a corner" is pretty open ended. I believe what you really want to know is how fast it spools up and at what rpm.
To put it another way:
What is the [minimum rpm] that you can go [from vac to usuable postive boost] in [a near instant amount of time].
[minimum rpm]
I imagine the results will be pretty similar for all rpm points above this point.
ie-stomp it and go, not put it in a tall gear at low rpm and stand on it so the low pressure exhaust flow has ample time to slowly spin the turbo up to speed.
Very well worded
Marty RE
Aug 17, 2015 09:36 AM
4sfeedit
Aug 16, 2015 01:42 PM
