rpm ?
Old Jun 7, 2003 | 09:29 PM
redboykid's Avatar
rpm ?
im pretty sure i have a t2 tranny in my 88 vert my question is this in 4th gear my rpm wont go passed 5200 but through the other gears it will any suggestion why this is
Old Jun 7, 2003 | 09:38 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I highly doubt you have a turbo tranny... there is so much different. you'd need to swap the whole drivetrain including clutch, starter, rear end, and driveshaft.
no idea why you can't go past that... never seen that before.
Old Jun 7, 2003 | 09:41 PM
vectorminds's Avatar
Where's My Fuel???
can you got past it in 5th.... your engine just might be weak and not making enough power to drive that fast.... other than that i cant think of anyhting
i also really doubt you have a t2 tranny, its really complicated to put in (you have to change the drive shaft and rear end as well)
Old Jun 7, 2003 | 10:30 PM
redboykid's Avatar
1st to 3rd i can past 5200 didnt try 5th it pulss pretty good other than that the reason why i said i think i have a t2 tranny is i had to buy a starter i went to 2 differ stores to get a starter they were both wrong there should be the same jusy differ st/my right and then of course the turbo thats what i had to get and it fit
Old Jun 7, 2003 | 10:39 PM
Where's My Fuel???
i think the turbo2 tranny has 3 drain / fill plugs on it... whereas the n/a one only has 2....
that should be a good way to check
Old Jun 7, 2003 | 11:03 PM
Evil Aviator's Avatar
Rotorhead
I'm not sure what the problem is, but a TII transmission wouldn't make any difference as it has the same 1.0 4th gear ratio as the non-turbo transmission.
The easy way to check for a TII vs. non-turbo transmission is to look under the car. A TII transmission will have a plate bolted to the bottom of the rectangular section, with a drain plug in the corner of the plate. A non-turbo transmission has no removable plate, and the drain plug is mounted on centerline fairly close to the center.
Old Jun 7, 2003 | 11:34 PM
DrifterFD3S's Avatar
im guessing that yur motors weak and cant push past the aerodynamics of that speed
Old Jun 7, 2003 | 11:42 PM
Scott 89t2's Avatar
SOLD THE RX-7!
5200 in 4th is not fast though.... like 90???
Old Jun 8, 2003 | 01:52 AM
Rotorhead
Yes, somewhere in the 90's depending on the tire size.
Old Jun 8, 2003 | 08:24 PM
redboykid's Avatar
didnt get a chance to check the tranny but anyways could this be a port maybe not opening i did over a hundred just not in that gear
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
musker
Oct 1, 2015 05:58 PM
