Anyone make DIY abradeable seal compressor housing?
Old Jun 6, 2003 | 11:13 PM
BLUE TII's Avatar
Rotary Motoring
So you know one of the newer turbo tweaks in production cars is to coat the inside of turbo compressor housing w/ a higher heat plasitc so it touches the compressor turbine and then spin it up to 100,000rpm and let the turbine "machine" the plastic to a perfect fit.
I have heard of ~10% increase in efficiency from this technique.
So wouldn't it be easy to plastic spray your own housing, disconnect the turbo intake and turn the compressor by hand untill it turns smooth enough to fire up the engine and spin it up to ~100,000 rpm open air vented?
Anyone brave enough to try it? I might bolt on my stock turbo just to try it out...
Ian
Old Jun 6, 2003 | 11:49 PM
astrochild7's Avatar
controlled kaos
you are nuts. but i can see what your talking about. you would think that we could just machine a closer fit at the factory...
Old Jun 6, 2003 | 11:54 PM
setzep's Avatar
Makes sence to me. Give it a whirl.
Old Jun 9, 2003 | 01:59 PM
RacerXtreme7's Avatar
NASA geek
I been wondering and wanting to do this for some time now also. Problem is finding a material that will handle the heat and not un-bond its self from the turbine housing.
~Mike.......
Old Jun 9, 2003 | 04:58 PM
setzep's Avatar
Yeah... it would have to be a material that woulden't harm the enigne so as the turbo wears the small amount of material woulden't harm the engine as it passed thourgh it.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
JZW
20B Forum
Aug 18, 2015 08:56 PM
