Fuel pressure regulator question
Old Jun 6, 2003 | 10:28 AM
Scrub's Avatar
bow leggin'
Question Fuel pressure regulator question
Okay I am doing the Extreme fuel upgrade from the Rx-7 store. I have a few questions. One has to do with the fuel pressure regulator. Does anyone have pictures of the install of the SX regulator? Also do you have to replace the Fuel pulation dampener as well? What else is needed when doing the Extreme fuel upgrade...such as O-rings and such? If people have pictures of the install it would be greatly helpful. I just want to make sure I know what I need to replace before I take everything out.
Thanks,
Dan
Old Jun 7, 2003 | 08:24 AM
Scrub's Avatar
bow leggin'
no one huh?
Old Jun 8, 2003 | 12:28 AM
Heath's Avatar
MAGNUM SE7EN
I plan on removing my pulsation dampener. Supposedly the Aeromotive FPR has built in pulsation dampening of sorts. I have the SX FPR and I'm hoping it has the same. Does anyone know for sure?
Old Jun 8, 2003 | 12:47 AM
jspecracer7's Avatar
1JZ powered
This is how I have mine ran.
Old Jun 8, 2003 | 01:13 PM
Scrub's Avatar
bow leggin'
Holy **** dude that is sexy....do you have any closer pictures? That is how I wanted to run mine, did you replace the PFD....I have heard you should...and that you shouldn't
Old Jun 8, 2003 | 02:37 PM
shawnk's Avatar
Perpetual Rebuilder
There are about 1000 threads on the fuel system and 1000 ways to do it. Do a search and come up with some more specific questions and I am sure you will get some more participation.
Shawn
Old Jun 8, 2003 | 03:06 PM
Scrub's Avatar
bow leggin'
are you serious? woah I might not have searched before I came up with these questions. Let my try that.
Old Jun 8, 2003 | 03:46 PM
1JZ powered
LOL...engine bay looks a little different now with my T-45S instead of the Turbonetics 62-1 in the picture above, but the fuel system is relatively the same. Basically I've got twin stock pumps feeding the primary/secondary rails and then used the Aeroquip Regulator as the "Y". Return line is the charcoal canister that no longer exists and then to a bulkhead fitting on my fuel tank.
Old Jun 9, 2003 | 01:08 PM
Scrub's Avatar
bow leggin'
Hey Jspecracer....How did you mount the pressure regulator there? I mean what did you use to secure it?
Rotospectre
Mar 28, 2018 03:33 PM
86glxNA
Aug 22, 2015 08:54 PM
