9000th boost problem
Old Jun 4, 2003 | 12:23 AM
mmonaco's Avatar
Part out my Car
my freind is have trouble getting the second turbo to spool! I checked all the vacuum lines on the pass side of the car and check everything nunver neith to, the turbis arent blow and a hose job has been done! He get about 8 lbs of boost and then i dies off to nothing its hard to tell if the second turbo is pre spooling or what is going on. but since i check all those lines i dont know wht to look for any ideas? the car has about 40k on it thank
Marc
Old Jun 4, 2003 | 01:35 AM
I'd put the car up on a lift and inspect the turbos thoroughly. Make sure the small horseshoe clip that holds the wastegate actuator arm onto the flapper door hasn't come loose. That's what happened on my dad's R1 in a similar instance.
Old Jun 5, 2003 | 01:55 PM
mmonaco's Avatar
Part out my Car
ok ill check that thanks for looking! Those damn heat sheilds make it a pain in the *** to look around! But ill have to put some more time into it!
Old Jun 5, 2003 | 01:57 PM
r0gu3's Avatar
Boostless FD
I forgot what a proper boost pattern feels like.
Old Jun 5, 2003 | 02:02 PM
mmonaco's Avatar
Part out my Car
LOL ya i think thats a common feeling! My advice for him was to take it to non seq and that should reveal the problem or the non will fix it!
Old Jun 5, 2003 | 02:08 PM
r0gu3's Avatar
Boostless FD
Yeah, I am going non-seq.
Old Jun 5, 2003 | 04:01 PM
Juster's Avatar
I went non seq and personally i dont like the lag.. im sticking to seq. thank goodness i did the poor mans...haha
Old Jun 5, 2003 | 07:50 PM
SleepR1's Avatar
Could be bad turbo control, precontrol, wastegate solenoids, or bad check valves...
Old Jun 5, 2003 | 08:42 PM
Dalen's Avatar
is switching to non seq at all good? will you lose any hp etc?
Old Jun 5, 2003 | 08:45 PM
SleepR1's Avatar
I wouldn't switch to nonsequential. I'd solve the problem @ hand instead of going nonsequential.
Old Jun 5, 2003 | 09:43 PM
911GT2's Avatar
The Power of 1.3
The non-seq debate is loooong, so I won't do it here, But i will say this.
I went non-seq on a stock ECU, and apparently the stock ECU is tuned for the "dip" in boost at 4500 rpm, and if you have 10psi there, and not 8, like I did, you run lean for a split second. And if you floor it onto a highway on a cold night, KABOOOM, blown apex seal.
So be careful if you're not tuned for it. Thats not to say that many people haven't successfully run non-seq with a stock ECU, because many have. But it could happen, and it is a big kick in the wallet when it does.
Old Jun 5, 2003 | 09:57 PM
paw140's Avatar
Are you sure about this? I've never heard anything like this before. I find it hard to believe that the stock ecu could not compensate for 10psi at 4500 rpm. I find it hard to believe that the people who tuned the stock ecu would have lean fuel maps *only* at the transition point.
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
tiger18
Sep 3, 2015 08:27 PM
