Quick question on boost level
Old Jun 3, 2003 | 11:52 AM
Ambitionz's Avatar
im sorry, I tried searcing for about 10 mins but couldn't find anything. My friend runs 14psi of boost on his stock twin 93 RX7. How much rwhp is he getting? Thanks al ot...
ps- are the stock boost level at 10lbs?
Thanks...
Old Jun 3, 2003 | 12:20 PM
r0t0r-rooter's Avatar
call me Smokie Smokerson
Stock boost levels are 10lbs. @ 14, I think your friend should be making ~ 255-265 at the wheels (~300 flywheel). Stock would be ~215-220 at the wheels.
I'm sure someone else can correct me if i'm wrong, but that'd be my guess
Old Jun 3, 2003 | 02:14 PM
BMike's Avatar
Depends alot on the mods, when you say stock twin turbo i assume your speaking only of the turbos, cuz a stock ecu would fuel cut way before 14 psi and if you used a FCD or the like you'd blow the motor at that boost without enrichment. A typical full compliment bolt on RX should make more like 320 rwhp <full exhaust work, intake, ecu for 1 bar, intercooler, etc> from what I've read here...
Old Jun 3, 2003 | 02:41 PM
oops, I thought he said that the friend's car was bone stock with just the boost increase. That's why the #'s I gave are kinda low
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
