Sponsored by: CARiD
intercooler piping problem
Old Jun 2, 2003 | 04:19 AM
inis's Avatar
I just got a greddy intercooler piping upgrade kit. On the stock elbow, right before the throttle body there is a relatively large hose. It spits out a little oil. What should i do, plug it? do i have to customize the elbow and reconnect it somehow?
and what does it do exactly?
Old Jun 3, 2003 | 05:32 AM
maxcooper's Avatar
WWFSMD
It is the AWS (Accelerated Warmup System) that runs the engine at a higher-than-idle RPM when you first start it up. It is intended to warmup the pre-cat quickly, but isn't good for the engine in terms of wear. It is perfectly fine to disable it if you aren't concerned about cold start emissions (few people are).
I suggest following the hose around to the metal pipe that comes out from the UIM by the firewall. Get one of those 5/8" or 3/4" (can't remember the right size) rubber heater core caps from the auto parts store. The brand name may be HELP! (that is the brand name, not a cry for help ). Remove the rubber hose and put the cap on the metal pipe. Hold it in place with one of those worm-screw hose clamps.
-Max
Old Jun 4, 2003 | 01:19 AM
inis's Avatar
reply
thanks for the help. Does just having the hose disconnected affect my boost at all. could it be the reason for some boost problems, or is a pure warmup thing?
Old Jun 4, 2003 | 11:00 PM
duboisr's Avatar
It is only a warm up thing.I would remove the hoses and use block off plates so it will look good on a good looking car.
Snoopy FD
Dec 8, 2015 01:45 PM
