just took all the tar out....
Old Jun 1, 2003 | 04:59 PM
onepointone's Avatar
i say what i want
what started as picking little peices here and there, and taking out interior of my project car, turned into 2-3 hours of fun for my neighbors. i started with a flat head screw driver and a hammer, then moved up to a chizzel and a hammer.. well i wasnt getting anywhere fast, so i remembered my dad bought an air chizzel that we have NEVER used, so i brought that out. things went a WHOLE lot quicker from there, but it still took a while. the only thing is.. i dont think it was worth it. that stuff didnt seem like it was that heavy, and after reading up in the race car section, someone weighed it and it was 16 pounds . im done for today , but i do have to sand all that **** down and paint over it so it doesnt rust on me, maybe tomorrow. point is.. unless your rex is a race car, dont bother, it wasnt worth all that time. i was thinking about doing it to my street rex since the interior is already out, but im not going to waste my time.
Old Jun 1, 2003 | 06:26 PM
wwilliam54's Avatar
it WILL run
i doesnt weigh much, but it sure made it easier for me to clean up the metal under the bins with it out
Old Jun 1, 2003 | 06:47 PM
RotorMotorDriver's Avatar
Seven Is Coming
The only tar I want to take out is the tar under the header panel by the windshield wiper motors. Mines all cracked, ugly, messed up, etc. I just want it all out so when you look down inside there its not all amazingly ugly and will look good when I repaint the car.
~T.J.
Old Jun 1, 2003 | 07:38 PM
Rx7carl's Avatar
Airflow is my life
If you remove ALL of it inside the car it is a substaintial amount of weight. (40lbs IIRC). Only reccomended for a racecar as it will be louder inside, unless you dynomat it and then whats the point?
Old Jun 1, 2003 | 08:59 PM
i say what i want
it sure didnt feel 40lbs, and a guy in the race section said it weighed 16lbs, which is practicle. its not that much in there anyway, its pretty thin.
oh well, its gone, its less weight, im not bitching its gone, i just dont think it was worth the time, and then now i have to sand it and paint it so it doesnt rust all to hell because that air chizzel definately put some dings in the metal
Old Jun 1, 2003 | 09:18 PM
WackyRotary's Avatar
standard combustion
Thats what I think unless your car is dedicated for the track and tubbed, the sound deadening isn't going to make a substanial difference. Unless that is along with all the other minor weight reductions.
If you had a powerful enough engine it wouldn't make a big difference on the street, just turn the boost up a little. But for the track, you DO go all out.
Old Jun 2, 2003 | 12:05 AM
Rx7carl's Avatar
Airflow is my life
Sand and paint? Mine came off and there was nice shiny gray paint underneath. Nothing to sand. Maybe you didnt get all of it off?
Old Jun 2, 2003 | 12:30 AM
f/p79's Avatar
On my 79 autocrosser, I started with a chisel, putty knife and screwdriver. Then bought a heat gun allowing me to heat and peel it off more easily. I still ended up with many scrapes and scratches. My friend stripped his off with a putty knife and screwdriver and NO scratches. Plus, mine is 2-3 colors of grey. His is one color. I'll try the dry ice method IF I ever do it again.
Old Jun 2, 2003 | 03:29 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
I still wanna take all my tar out so I can get what's left of that stupid furry carpet bottom **** off the floor.
Old Aug 25, 2013 | 10:59 PM
MilkStout's Avatar
i used dry ice and got the whole car minus the sides of the tranny walls. took prolly an hour total and about only 60lbs of dry ice. theres a ton of tar in this car.
Old Aug 26, 2013 | 01:33 AM
NCross's Avatar
I have a rotary addiction
FC has more. I stripped one of mine. Pain in the butt and not worth it.
Old Aug 26, 2013 | 10:48 AM
woodmv's Avatar
Village Idiot
I saw Aaron Cake's video about this just last week. Interesting. Looked easy and most of it popped off like the chocolate coating on an icecream bar. He started with a screwdriver and hammer, then went to the air hammer and it popped off nice and easy for the most part. Never would have come up with that idea on my own!
Old Aug 29, 2013 | 12:12 AM
rotornoob's Avatar
emissions r teh sux
Yeah I did my 82 and it was a pain in the starfish. Probably going to do it to my 85 before I get it prepped and painted but I will use a heat gin this time. Maybe dry ice if the heat gun doesn't work well enough. Last time I just used a sharpened putty knife and a hammer...not so much fun..
Old Aug 29, 2013 | 12:35 AM
theNeanderthol's Avatar
the torquinator
Woah. 10 plus year old thread resurrection. I have a feeling that if someone were doing a very thorough restoration, and you were to take out ALL the tar, and replace it with the newer butyl rubber based dynomat type stuff, the car would end up both quieter and lighter. Would be a ton of work though.
Old Aug 30, 2013 | 12:56 PM
mazdaverx713b's Avatar
Have RX-7, will restore
nowhere near worth the effort on a daily driver. you drive a sports car, expect some road noise and don't waste your time removing the factory sound deadening, as it does its job well and will prevent rust and corrosion.
California style
Aug 26, 2015 03:45 AM
chiminoid
May 20, 2003 04:05 PM
Relisys190
May 10, 2003 01:15 PM
Bruhman
Feb 8, 2003 10:14 AM
LittleBlue
Race Car Tech
29
Dec 13, 2002 07:27 PM
