Exhaust manifold gasket
Old May 29, 2003 | 09:48 AM
apexkw's Avatar
in slow, out fast!
i thought there was a way were you could use a different manifold gasket that was one piece instead of the 2 piece design that the 3rd gen uses. also i thought that the one piece unit was cheaper than the $130x2 a piece gaskets that mazda sells. anyways if you guys could help me out that would be great.
Old May 29, 2003 | 11:00 AM
IRPerformance's Avatar
Sponsor
2nd gens have a 1 piece gasket. I haven't tried to see if it fits though.
Old May 29, 2003 | 11:15 AM
I have a 2nd gen gasket laying around, I will measure it tonight. Carl Byck
Old May 29, 2003 | 11:18 AM
TYSON's Avatar
WTF is wrong with it now?
I have a 1 piece gasket from a Greddy kit. Bought it for $25 CDN.
I have an AutoCAD drawing of it here.
Old May 29, 2003 | 01:29 PM
DaleClark's Avatar
RX-7 Bad Ass
There's no reason the 2nd gen gasket shouldn't fit. Matter of fact, I've test-fit an exhaust manifold that was designed for an FD on an FC block - as far as the flange and bolt holes, it fit fine.
The only problem might be if you were worried about emissions/EGR - the EGR hole might not line up.
That said, the '87-91 TurboII's use a heavy duty stamped stainless gasket that's REAL durable. It's about $50 or so new.
Dale
Old May 31, 2003 | 01:09 AM
Jetlag's Avatar
I've used the T2 gasget on my 3rd gen with no problems.
Kyo
Apr 13, 2019 09:24 AM
