It's been geeked out!
Old May 27, 2003 | 06:44 PM
I got my carputer installed. Everything is wired, and the funniest thing is that the stock alt will work..... as long as i stay above 1.5k rpms. If i can get my hands on a digital camera i will post some pictures of it tonight. Now i just have to figure out how i can keep my eyes on the road while i have music vidoes/dvds/sealab epps.
On a sorta related side note, does anyone have any 13b housings in descent condion for sale on the inexpensive side? I just started pulling my se engine appart, and it looks like the coolant leak was caused by the housing giving away at the seal... Doh.
~Blitz
Old May 27, 2003 | 06:54 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Re: It's been geeked out!
~Blitz
werd to sealab eps :P
Old May 28, 2003 | 12:23 AM
ah ok 100 posts new avatar
Old May 28, 2003 | 12:29 AM
Jeff20B's Avatar
Lapping = Fapping
So you put a computer in your car? I'd like to do that to have lots of music available.
Old May 28, 2003 | 02:28 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
i have a full -se motor 4 sale... great compresion #'s and looking in the exh ports there is NO carbon in the motor... i got it from a -se i bought as a parts doner for the t2 swap... P.O. said the motor was replaced just b 4 the car was wrecked. motor comes with main pully, waterpump, intake and wireing harnessand all the JUNK under the intake. and flywheel. 1050.00 with the light alum. flywheel of 750.00 with a stock flywheel. plus shipping or i can meat you half way...as your only a state apart... for a little gas $ that is
Old May 28, 2003 | 08:00 AM
anthrax's Avatar
Heck Yes!
Geek Power!!!!
Strange things hapen when you leave a geek to their own devices.
Pics would be cool
What OS are you running?
what are the specs on the box?
Hey have you got wireless? That would be real cool for wardriving!! You could map out all the wireless access points in your area. Now that would be sweet
Old May 28, 2003 | 08:22 AM
okk0to's Avatar
maurice lives!
man, if you could connect to homestarrunner.com i would see no reason to ever leave your car.
Old May 28, 2003 | 03:33 PM
Alright, pics should come tonight if all goes according to plan.
The Box:
Mini itx motherboard, cyrix/via 1Ghz processor. 256mb ram, onboard video with rca and s-vid tv out, sound(5.1), and lan. 40 gig, 24x cdrom. Wireless card should be comming with my next paycheck.
Oh yeah, GPS, for traveling, and pinpointing networks when wardriving. 7.2" starvision lcd. It will go in the dash of my SE when i get done rebuilding it. But its mounted in my Gsl right now. I have a touch pad that i put in where the stereo fader used to be so i can control differen't programs, and a mini usb keypad so i can use all the winamp controls easily without a full keyboard.
Best thing about a mini itx setup is that it requires a 12volt input. So you don't need an inverter, though i recommend one. The power from your accessory output jumps alot, and its better to condition it before you run it into a computer. Not to mention the case is about 12"X11"X2", and was originally going under my seat, but i decided to just velcro it down in the back.
To solve a little bit of a power issue, im going to wire in my spare t2 alt tomorrow, then everything should be good to go.
As i said before, i should have pictures later on tonight.
~Blitz
Old May 28, 2003 | 03:38 PM
Anthrax, i'll consider that. Though after i got done posting, i was talking to a friend of mine, and his bud has an 87 engine he wants to get rid of. The engine runs, with low compression on the rear rotor. So the guy is going to pull the engine apart for me, and see what condion its in. Best part of it is that i get a complete engine for $50. ITs been a while since i have been this lucky!
~blitz
Old May 28, 2003 | 03:46 PM
anthrax's Avatar
Heck Yes!
Sweet
Look @ X10's web site they sell a remot control unit designed to work with your PC I have one works great. It might make it a bit easyer for you to control while driving.
Thats sweet!!
So is the case like an old dumb terminal case or somthing? to be that small
Now just make it run Linux and it'll be that much sweeter
Old May 28, 2003 | 05:34 PM
vipernicus42's Avatar
Rotoholic Moderookie
At the Ottawa Rx7 Meet I met a guy who hangs out in the Canadian forum called AaronCake. He's got a cool Mp3box setup for his car.. It's a stripped-down comp, in a clear plexi case that he made himself. He's running a majorly stripped-down version of Windows9x, and is interfacing thorugh a small set of buttons he rigged to the serial port and progged an interface for. The computer responds to the commands with a voice synthasizer through the speakers... I thought it was pretty cool. It's easily removable too, so right now he's got it ported into his funky Gas/Electric hybrid car, until his cool-*** secret Rx7 Project car comes to light I'll say nothing more :P
Jon
Old May 28, 2003 | 10:02 PM
Alpine makes car MP3 players that use 16GB hard disc for storage.
Old May 29, 2003 | 12:22 AM
wagondriver69's Avatar
Yea, I have a 10 gig MP3 Player, about the size of a calculator, and an FM transmitter hooked up to that. Its really great, id reccomend it.
Old May 29, 2003 | 02:25 AM
Jeff20B's Avatar
Lapping = Fapping
I've got a P60 in my garage hooked to an FM transmitter so I can either listen to songs with a walkman, or a set of speakers while I'm working. I'm gonna upgrade soon, but this P60 has well over 24 hours worth of songs on it loaded into a winamp playlist. It happily plays songs all day, every day.
demetlaw
Oct 2, 2015 06:22 PM
