Microtech Where Is the response for na's and MT?
Old May 26, 2003 | 07:18 PM
silverrotor's Avatar
I'm not seeing much of an Interest with na owners and going with MT.
No one here to kick start the Golden Generator?
Old May 26, 2003 | 08:24 PM
No7Yet's Avatar
We just did an install into Silver88GXL's N/A.
We'll let him tell you how it drives.
Brandon
BR7 Racing
Old May 26, 2003 | 08:25 PM
JerryLH3's Avatar
Rabbit hole specialist
I'm interested, but it has to wait. Suspension has to come first, at least to me it does. Yummy - coilovers, new bushings, sway bars, it gets me excited!
I'm probably about a year away from purchasing, so I'll let others beat me to the punch.
Old May 27, 2003 | 01:40 AM
10sec rx7's Avatar
ive fitted heaps to na cars, work a treat!!
Old May 27, 2003 | 08:48 PM
No7Yet's Avatar
https://www.rx7club.com/forum/showth...hreadid=190602
For all who are interested.
Brandon
BR7 Racing
Old May 28, 2003 | 12:42 PM
banzaitoyota's Avatar
What Subscription?
I'm interested. I am sending my MT-8 back to Dale for the LT upgrade.
Question: Can the boost sensor (1 bar & 2 Bar) be seperate components (ALA 3 BAr) to give me the ability to switch my Lt-8 ECU between my NA and my TII?
Old May 28, 2003 | 05:04 PM
I F****D a mermaiiiid
nope. the computer is fitted with a factory internal 2 bar map sensor or the External 3 Bar option. If you are running a 3bar map on your car and want to swap the computer over to your na all you need to do is get another 3bar map sensor for the NA. Yes it is overkill but the system can only be configured to run one type of sensor at a time. The sensor works by manipulating a +5Volt refference signal to the ECU. Each MAP sensor interprets the same manifold pressure differently and supplies a different voltage. The computer you have configured to read a 3bar would interpret the signal from a 1 or 2 bar sensor differently causing the computer to access the wrong load points.
Ray
BR7 Racing
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
