broken nipple on double throttle control valve
Old May 25, 2003 | 08:14 PM
jayk's Avatar
While trying to test my check-valves I broke the off the nipple to what I'm almost positive is the double throttle control valve. The check valve was the green and white smaller one connected to the UIM.
I have two questions:
1) How hard would it be to get to the solenoid and replace it? It looks like its buried pretty deep in there and I have a feeling I'd end up with a much bigger job than I intended.
2) Can I drive the car without this hose connected? Will it just disable the double throttle?
Thanks for any help.
Old May 25, 2003 | 08:41 PM
BoOsTin FD's Avatar
Powered by** Rotary
same thing happend to me. So i just ended up removing double throttle all together. It's not that hard, and saves you all the trouble from replacing that solenoid.
I don't know if it's good idea to drive it with it broken because it might be closed and that way you will loose some boost.
You can do a search on double throttle removal.
Old May 25, 2003 | 08:42 PM
puma's Avatar
canadian monster
you don't need the double throttle, just make sure you don't go WOT when the car is cold, it's the only purpose of that thing.
almost everyon on the board removed it.
check rob robinette web's site for a how-to
puma
Old May 25, 2003 | 08:45 PM
puma's Avatar
canadian monster
nope, leaving the actuator with nothing attached to it will leave it open. just put a bolt in the hose (where was the check valve) if you don't want to remove the UIM
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
