tried to wire a cd player (disaster)
Old May 25, 2003 | 05:41 PM
Castrol86GXL's Avatar
ok i though i could wire in a cd play with the stock speakers and just remember the color code for each then i cut the wires off the back of the stock radio and just started hooking up the wires and nothing works is thier any type of relays from the speakers that would not let it have direct connection from the speakers to the cd player? and the cd player is Max Output 60w (4 ch) and you know the stock speakers are Max 25w . Would this blow the stock speakers??? i just though i could do this myself instead of taking it somewhere
Old May 25, 2003 | 07:53 PM
keynote22's Avatar
you'll need the diagram found here :
https://www.rx7club.com/forum/showth...threadid=25090
If you have a bose system you'll need a Bose/Schosche Adapter found here:
good luck
Old May 25, 2003 | 07:56 PM
can i just take 10 guage wire and wire it directly?
Old May 25, 2003 | 07:59 PM
oh wait 2 more questions
1. The power source says to hook it upto the ignition. how the hell do i do that because it needs something that turns of with the car. could i just hook it upto the cig lighter???
2. the Memory says just 12 volt so can that just be to batt???
Old May 25, 2003 | 08:29 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: tried to wire a cd player (disaster)
Assumptions are the mother of all f^%k ups. Id recommend taking it somewhere and getting them to bail you out of this disaster, dont be suprised tho if the labor is now $30 or so more than it would have been if you didnt mess with it. Sorry to be blunt, but if you havent a clue, then you shouldnt be attempting it
Old May 25, 2003 | 08:44 PM
rxtasy3's Avatar
Yeah, what he said. ^
Old May 25, 2003 | 09:03 PM
hmmm well thanks for the help though
Old May 25, 2003 | 09:13 PM
MIKE-P-28's Avatar
Didnt want to sound like an ***, if you were local Id help you, but its gonna be pretty differcult for me to educate you in 13 years of car audio professional installation experience in 5 minutes
Old May 25, 2003 | 10:14 PM
no its ok i just thought i could direct connect it im not looking for permanent install i just want some sound untill i get professional thats why im talking about stock speakers i gots good speakers i just want temporary untill i get an amp. i just wanted some help like with the questions above
Old May 26, 2003 | 10:05 AM
Hyperite's Avatar
Vagina Junction
Probably should've used a harness...
Old May 26, 2003 | 02:53 PM
nataku's Avatar
well u could check to see if u blew any fuses, u made sure to disconnect the battery b4 u did this right?
Old May 27, 2003 | 12:25 AM
i got it working, just rewired everything now its great
Old May 27, 2003 | 06:30 PM
nataku's Avatar
did u have to pull off all the trim to rewire everything?
Old May 27, 2003 | 07:13 PM
no i hid it pritty well no one can see one wire or find one and didnt remove anything
Old May 28, 2003 | 05:56 PM
nataku's Avatar
oh, so you didn't have to remove the old wiring? i'm planning on redoing the wiring too, but i was going to remove the old stuff too, i guess there is no point in removing it...
Old May 28, 2003 | 11:08 PM
i would want to come over to help but you live too far away sorry
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
