Microtech microtech 2 bar stock map sensor
Old May 25, 2003 | 03:32 PM
Tim Benton's Avatar
FD title holder since 94
After looking at the software for the first time last night, it was a 3 bar setup that had data point up to 28 psi. With the stock 2 bar sensor in the microtech, what does it go up to? 15 roughly? If so, whats it peak psi range, not the 28 psi hopefully.
Tim
Old May 25, 2003 | 11:10 PM
10sec rx7's Avatar
Its actually a 2.5 bar map sensor and the maps go to 20psi.
Dale
Old May 26, 2003 | 12:34 AM
Tim Benton's Avatar
so what's the upper data point for it? if it goes to 20 psi, you don't need for maps that go to 28. Does it drop down to 20 psi for the upper limit, giving you better resolution up to 20?
Tim
Old May 26, 2003 | 06:29 AM
rxeng's Avatar
Tim.
The standard ecu & the 3 bar have the same number of load points but on thye 3 bar version the vacuum side points are spaced further apart to allow for a few more in the 20-30psi range.
Jon
Old May 26, 2003 | 11:04 AM
Tim Benton's Avatar
Thats what I was wondering and thanks for the answer. Brandon and Ray both impressed me with the ecu, but I still had a couple of questions.
Thanks
Tim
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Snook
Aug 15, 2015 08:18 AM
