Coolant and Engine Temp Questions
Old Sep 4, 2001 | 12:48 AM
Ok, first question is : After rebuilding an engine, how do you fill the coolant?
After I rebuilt mine, I took off the top screw of the radiator, Then dumped in coolant into the filler until coolant came out that radiator screw on the top of the radiator (the air bleeder screw)..
put the screw back in, and topped off the coolant , squeezing the pipes to get last bit of air out, and bumping car a little to shake any more out... topped off coolant.. and done..
Is that the right way? how do I know if I got all the air out?
Question #2:
After putting my engine and all back in, I did find a leak of coolant at the water pump housing to engine... (I chopped that gasket up pretty good... have a new one on the way as I type...) so my overflow isn't being sucked into the engine.. Therefore I have to fill it before driving.... and my temp gets near half sometimes.. usually sits at about 1/4 (which is still hotter than it was before I had to rebuild..) When I fix this coolant leak, will it lower my temps much/at all?
Question #3: I read that the 13B is cooled 40% (around there) by OIL... And I read that people would take their front ECC shaft thermostat out, and replace it with a bypass (like the one on mazdatrix page) or use washers to bypass it somehow...
What exactly does that thing do? What does replacing it with the bypass do ? Any BAD things that go along with using a bypass ? or ALL good things? Could that be the cause of my increased temp ?
Thanks for any help you can give me guys! Green..
Old Sep 4, 2001 | 12:59 AM
Scott 89t2's Avatar
SOLD THE RX-7!
Re: Coolant and Engine Temp Questions
this will not fill it all the way. after you do this you start the engine with the heat on full blast (important) and cap off. once it starts to warm up the level will drop quite a bit. just keep adding coolant as it drops. it'll probably take a good 20 mins of warming up before it's full. I just changed mine and added a good 2 quarts durring the warm up even though it was full before I started it.
alphawolff
Nov 17, 2015 05:57 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
