Explain turbo language please???
Old Sep 3, 2001 | 11:41 PM
Scott 89t2's Avatar
SOLD THE RX-7!
are you upgrading your stock turbo or getting a full t04 setup with new manifold and external wastegate??
if you are upgrading find a 89-91 turbo and manifold and do that one instead.
can't help you on the numbers...
Old Sep 4, 2001 | 12:15 AM
adamlewis's Avatar
Back from teh deadly!
Originally posted by t2project
I'm definatly going with the to4 new setup. HKS makes a manifold for me for $250 with external or internal wastegate option. On the wastegate, is external or internal better? thanks for the help
I always heard external was better but Im no expert
Old Sep 4, 2001 | 12:53 AM
Scott 89t2's Avatar
SOLD THE RX-7!
external is way better. half the reason to upgrade the turbo.
stock is internal.
I don't like the HKS manifold. it sticks out to far to the side and is not divided. My friend has the HKS manifold and had to bang a dent in the frame rail to clear the turbo. you would be better off with a divided manifold, more power and quicker spool up. not sure who makes them.
Old Sep 4, 2001 | 03:18 PM
Bob's Avatar
Bob
Try SOUTH FLORIDA PERFORMANCE. Ask for Juan. (305)233-8520
Make absolutely certain he knows the year and model of the rx7.
A divided manifold will run about 425 (estimate). With s&h + a custom flage for the 50mm w/g, mine ran me 550.
You will need an external w/g, the lines to and from the turbo, a bigger I/C, and lots of fuel.
I will be using the following turbo with a HALTECH w/2-700's and 2-1600's
Turbonetics-t66
Tuff turbo option
Tangw/divided 1.15 a/r housing
Ball Bearing
P trim
I have now switched to a .96 housing for the street.
According to Brian Cerny of Turbonetics there is not a whole lot of difference between the 60-1 and t66 until you get above 20psi, then the t66 flows more cfm; however, the 60-1 will have slightly less spool time. This is why I opted for the BBt66 turbo.
The1Sun
Mar 18, 2018 11:08 PM
VTECthis
Aug 24, 2015 09:01 PM
sypath
Aug 23, 2015 10:15 PM
