Urgent Fuel Pump Advise
Old May 24, 2003 | 08:45 AM
msimonov's Avatar
OGTA
Question Urgent Fuel Pump Advise
I think the fuel pump is gone on my car. I am running a 12A with a stock carburator. I searched a little for a replacement fuel pump on the net and it looks like most places will have to order it. However, Advanced auto stocks a Holley Avenger Street Performance pump. The specs are a little higher than the stock. Stock is 3.7 to 4.7 psi. The Holley comes set at 7 psi, but the write up talks about 5 psi flow also, I'm thinking it may be adjustable.
Will I need a regulator to run the Holley or will 5 psi be close enough (assuming it is adjustable)? Is this even worth doing for a stock carb?
Old May 24, 2003 | 09:04 AM
mar3's Avatar
Administrator
The stock Nikki likes to see something in the 3.0 to 4.5 range, so you MUST use a regulator with the old tech Holley fuel pump...just get a Facet. If you don't plan on any big mods in the near future, it's more than adequate and a whole hell of a lot quieter...
Old May 24, 2003 | 09:28 AM
msimonov's Avatar
OGTA
I just pulled the fuel in line and tested for the volume flow and got NO fuel in 30 seconds. I changed the fuel filter yesterday, so I am pretty conviced the pump is gone - plus I don't hear it run at all with the key in the on position.
Mar3, I assume Facet is brand name you are recomending.
Anyone else have a brand recomendation?
Old May 24, 2003 | 09:33 AM
diabolical1's Avatar
yes, Facet is a brand name. and i concur with mar3 ... if you don't plan any major mods in the near future a Holley or Carter will be overkill and probably just plain annoying (with sounds and mounting woes).
Old May 24, 2003 | 09:50 AM
inittab's Avatar
I read your email
Since you have an 85 GSL, your fuel pump will not run when the key is in the "on" position. The pump only runs when the key is turned to "start" or the car is "running". This is true for 84-85 model years.
Old May 24, 2003 | 09:52 AM
mar3's Avatar
Administrator
On the '84/'85 cars, the engine must be physically turning in order for the fuel safety relay to close and energize your fuel pump. Even with the key on the on position, the pump will work for only a quick second and then turn off if the engine eccentric isn't moving...
Old May 24, 2003 | 09:55 AM
msimonov's Avatar
OGTA
inittab, intresting point.
But, I don't even hear it run for a few seconds when I put key in the on position. I know, it use to come on for a few seconds when the key went in the on position.
How would you check the fuel flow on an 84-85?
Old May 24, 2003 | 10:20 AM
mar3's Avatar
Administrator
PM V8kilr on how to put jumpers on the relay...that's how he gets all his cheap cars from the unsuspecting public...
Old May 24, 2003 | 11:16 AM
inittab's Avatar
I read your email
When I rebuilt my fuel system I simply hot-wired the fuel pump so it would fill the lines. I used the connector under the drivers side storage bin.
--Bob
Old May 24, 2003 | 11:42 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
The Facet pumps are internally regulated to 6 psi, which is a bit high for a stock application. I'm currently running an RX4 pump which is also a bit high, and I really need to get a regulator. Just a little heads-up.
Old May 24, 2003 | 01:00 PM
mar3's Avatar
Administrator
Just like Holley and Mallory, there's more than one Facet model....they have 4.5 psi models...
Old May 24, 2003 | 01:04 PM
specRX7_22's Avatar
3.0-4.5 psi stock nikki? isnt that a little high?
Old May 24, 2003 | 01:19 PM
31rx7's Avatar
Per other posts the engine must be turning for the pump to run on the 84-85 models. Easiest way to check to see if it is running is to disconnect the rubber fuel line from the carb and crank it over. Get a can or something to catch the spillage. You should get plenty of gas. If little or no comes out, then follow the Haynes manual on the hot wiring the fuel pump relay to verify the pump is getting juice. If it is, then the pump is likely bad.
Just to state the obvious, make sure there is gas in the tank.
Old May 24, 2003 | 02:13 PM
mar3's Avatar
Administrator
just don't get hot wire sparks jumping if you're filling an open container with gasoline....
Old May 24, 2003 | 02:49 PM
have you done any mods lately bcuz i just swapped engines and i have no fuel we are in the same boat and drowning
Old May 25, 2003 | 07:19 AM
msimonov's Avatar
OGTA
I found a fuel pump at NAPA. It is made by Carter (Federal Mogul). It is a universal fit pump and has everything you need to convert from a mechanical pump to electric. Anyone have any expericance with Carter pumps?
I checked the FSM and the spec for the fuel pump is 2.84-3.54 psi, 1400cc or more per min.
Unfortunately, I can find any specs on this NAPA/Carter pump.
Old May 25, 2003 | 08:14 AM
Pittdp's Avatar
I bought a carter from british victoria about 3 years ago and just put it on and it works great, no more power fade after 6k rpm. I cannot remember what the psi was though, mazda trixs has the original fuel pump for a good price. www.mazdatrix.com
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
