my bov isnt sounding or realeasing air...
Old May 24, 2003 | 06:04 AM
driftab's Avatar
Newbie
i jus installed a Blitz bov in my fd, but for some reason it doesnt seem to be releasing any air, or making a single sound...i still have the stock seq turbos...i have loosend the top screw, and even tightened it, what could it be??
Old May 24, 2003 | 06:51 AM
WVRx7's Avatar
It could be that your stock CRV (charge relief valves) are doing their job and not allowing what you purchased to function.
Why in the world would you buy a BOV for the stock twins? Come on, that pffft noise can't possibly be worth the money?
Unless you completely removed and plugged the originals, you now have 3 blow off valves.
Old May 24, 2003 | 12:43 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
BOV's are a waist of money on the stock twins. The stock BOV is perfectly capable of handling any compressor surge that you may have with the stockers.
Why don't you put things back the way they were before you installed it, sell the aftermarket BOV, and use the money to get a useful mod.
Old May 24, 2003 | 01:08 PM
BigIslandSevens's Avatar
did you make any boost before the install? i agree with going back stock and try again. if it still doesn't do anything than you have other problems.(vaccum lines etc...)
Old May 24, 2003 | 02:13 PM
r0t0r-rooter's Avatar
call me Smokie Smokerson
If you replaced the stockers with the aftermarket one, it's HIGHLY likely that the hoses from the y-pipe and so on were cracked in the process of swapping. That area by the turbos get really hot, and crack around the connectors. To check I would let the car idle, have a cig, and see if the smoke is being blown by any leaks
Old May 24, 2003 | 05:04 PM
driftab's Avatar
Newbie
i replaced the stock bov and left the crv, and i like the wqy the blitz looks...but i still cant seem to find the problem...should i send it back?
Old May 25, 2003 | 06:11 AM
driftab's Avatar
Newbie
ok, i fixed the problem
Old May 25, 2003 | 07:24 AM
rybrx7's Avatar
what was up with it?
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
