My Car
Old May 21, 2003 | 11:15 PM
My Car
THE CAR MY COUSIN WAS TALKING ABOUT, IS MINE! I BOUGHT THIS CAR ABOUT A WEEK AGO, AND I'M TOO IMPATIENT TO DO STUFF, I HAVE BEEN WANTIN TO BUILD A CAR SINCE I WAS 14. THE FIRST TURBO IS GOING OUT. SO AS MY COUSIN SAID, WE WERE PLANNING ON PUTTING A SINGLE TURBO KIT ON IT. THE KIT IS FROM GREDDY, IT'S A T78, COMPLETE WITH INTAKE, WASTEGATE, DOWNPIPE, AND SOME OTHER GOODIES. I WANT TO MAKE THIS CAR AN ANIMAL. SO HERE IS MY PLAN. PUT ON THE NEW TURBO FROM GREDDY. THEN BUY A TUNING SYSTEM, PROBABLY APEXI. NEXT, A BOV, DON'T KNOW WHAT KIND. THEN, AIR FUEL, BOOST, AND WATER TEMP GAUGES. THEN LIKE YOU SAID, I WILL DO A BIG FRONT MOUNT INVERCOOLER. THEN SOME OTHER STUFF THAT WILL ULTIMATELY EQUAL MORE POWER! I AM MOSTLY LOOKING FOR OPINIONS ON THE BOOST. WE WERE GOING TO ORDER IT NEXT WEEK, THEN PUT IT ON AND RUN LOW BOOST, TO HAVE IT READY FOR THE OTHER STUFF, THEN CRANK IT UP AFTER THAT. TELL ME ALL OF YOUR INFO, I'M VERY INTERESTED IN LEARNING, AND I WANT THIS CAR DONE RIGHT AND TO BE FAST AS SHIAT! THANK YOU SO MUCH FOR THE HELP!
Old May 22, 2003 | 12:32 AM
styxx8602's Avatar
Old May 22, 2003 | 12:35 AM
I would start slow and work your way up to the single. Im not the most all knowing knowledge of the fd but I know that probably isnt very healthy for it. First thing I did was to switch out my radiator and ast tank to get the more reliable stuff first. I then have since gotten the downpipe and exhaust and intake. BPU stuff is now on the car waiting to save up for the computer and then to get it tuned. I would then go with the front mount and work my on down. But my only point is that my last mod is going to be the big single. You will be pushing so much power that the fd from what I here is starting to get very unreliable and a very fun car but not a fun daily driver. If you have a daily driver you have nothing to worry about. But I would get the car ready for the single first before you put it on have fun with the twins for now and then go single. Also I would definately get the fmic before the single because if you have the single on but not the fmic you cant even run at full boost until you have the fmic on the car. And if you are made of money you have nothing to worry about but if your not you need to realize that alot of the parts are very expensive and it takes a while to save up the cash but just food for thought good luck and I hope it all works out for you.
This is just my opinion and the plans for my car so you dont have to take my advice by any means.
Good Luck again.
Old May 22, 2003 | 12:43 AM
Flyrx7's Avatar
Money Pit
First of all, QUIT SHOUTING.
Second of all, it sounds as if you have done a little research and are at least aware of some of the FD shortcomings. If you are going to go single be prepared to spend an *** load of cash, start locating rotary tuner shops in your area that can dyno tune, and above all else, rob a couple banks (did I mention it's gonna cost $$$)?
At any rate, if it all works out for you you will not be dissapointed, but like I said, don't expect to roll over in the morning and all of a sudden expect to see Cindy Crawford, it's not that easy.
Good luck.
Frank
Old May 22, 2003 | 07:11 AM
MR_Rick's Avatar
Planning my come back
you have a good list but you are starting backwards the turbo is the last thing you want to get. If replacing the turbos is getting to the piont that is a need you may want to consider a BNR kit at least you can run it with the stock everything else. TAKE YOUR TIME
Old May 22, 2003 | 08:44 AM
dubulup's Avatar
development
Learn to drive first
Old May 22, 2003 | 09:04 AM
Fish's Avatar
You missed out a couple of small parts like the EMS and fuelling system.
I think you need to sort those out BEFORE doing any of the modifications that you say you are going to do.
I take it that whilst your building your little monster, it will be kept off the road? If its not, then please let me know and I will fly over to watch its first and ONLY trip out of the garage, as it wont last more than two minutes on the road.
Dan
Old May 22, 2003 | 11:36 AM
BoostCrzy's Avatar
Doritos on a toothpick
get gauges first to make sure your car is staying alive during this....lol...id get a boost gauge even if my car was completely STOCK!!.....probably the single most valuable tuning tool for these cars....
Old May 22, 2003 | 11:58 AM
moehler's Avatar
And there goes another FD...
Old May 22, 2003 | 12:03 PM
twinturborx7pete's Avatar
Juris Doctor
Old May 22, 2003 | 01:41 PM
tomaszjc7's Avatar
ahhh... I remember when I was in the "upgrading craze" stage, then i realized i was broke.
Old May 22, 2003 | 02:28 PM
c00lduke's Avatar
Hey DLOSHCKE,
I buy a bunch of things from your cousin and tony and was talking to him about your car last time i was in there. I'm thinking the way you want to go might not be the best option unless you have large amounts of money 10-15k to put into the car and large amounts of knowledge about these cars. If you ever want to know what you should do or have me explain to you why just the turbo kit isnt enough we could meet at your cousin's shop and go from there.
If you have any question give me a call
9132192773
~Luke
Old May 22, 2003 | 02:42 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
I used to think the same way but then one day I did the math...
forget it! I'll be happy with just intake, exhaust, dp and an ECU.
Old May 22, 2003 | 02:54 PM
Shinobi-X's Avatar
Sensory Experience
Re: My Car
Get a guage. It's one of the most important things you should do FIRST...that and a temp guage will save you roughly 90% of the trouble you may run into (as in identifying it).
Then you must realize, this will take time, and you cannot have enough patience. Some searching on the forums, will be your best tool for reference. Studying the car can only help you if you plan on doing these things you say. They are all able to be done, but it's important to know about the work, and effort that goes on behind it- mainly making the car reliable first. That is where you should start, rather than boost, or power upgrades. Your car will not be a beast, if you first do not pay attention to the cooling system. And before you really get into the heavy mods, it may be good to learn how to drive the car a bit, if you haven't already. FD's are predictable, but they are also very fast cars, that can get the better of you if you are not careful. Good luck, and have fun, but remember, it's a great car, but it's very unique in that it requires specific attention to detail.
Old May 22, 2003 | 03:00 PM
alberto_mg's Avatar
i sense a blown engine in your future...
seriously, i just got one too and i plan on doing nothing to it till i figure out what i can do w/o blowing up the rebuilt motor i'm putting in. calm down a bit and think this through before you wind up with a dead car and spending all your money.
Old May 22, 2003 | 07:01 PM
rx7speed811's Avatar
Accepting Donations.
hmm... setember 6, 1986... you are my little brothers age. i would recommend opening up your ears to some of these guys before even driving your car stock, let alone adding one of the most impractical street turbos out there. unless you have lots of experience with the rotary and its quirky nature, which you will need in order to tune it correctly without blowing everything up, you will just **** up a perfectly good fd.
learn to drive first.
Old May 22, 2003 | 07:16 PM
93BlackFD's Avatar
built my own engine
okay guys, i'm going to be taking bets on this thread, as that's all it's becoming useful for
i propose that he
a.) blows his motor
b.) already has engine issues
c.) puts another FD in the graveyard
anyone against me on this?
Old May 22, 2003 | 07:25 PM
silverflash2's Avatar
I undertsand your thought on when something breaks always upgrade with a new part.But the problems is with the rotarys,like some of the posts above say,you really want to do the reliablity mods and upgrade the cooling system befor adding power.More power (boost) more heat and the stock system is definately not efficent enough. motor will be next if not. If i was you i figure out why your primary turbo went out, to prevent other damge,and pic up some low milage stock twins off this forum,and it's always a snow ball effect. Why do you thick your primary turbo is out. It maybe just your pre cat clogged.That will rob alot of power.And a boost guage is the only way to find out,what's going on with your turbos.Good luck. JC whitney has boost guages for like $25. It's a start
Old May 22, 2003 | 07:31 PM
Kento's Avatar
2/4 wheel cornering fiend
Not me.
lol, Twinturborx7pete, that's a great picture.
Old May 22, 2003 | 08:03 PM
particleeffect's Avatar
omgwtfposlol
gee, you don't read nearly as many "i bet he'll blow his engine" posts on non rx7 websites. damn him for not being a rotary expert just to keep it running, it's not his fault the motor is made out of balsa wood and rice.
but jesus WATCH THE CAPS. slow down, read the faqs -no one seems to. and don't bother getting to far ahead of your wallet. can you afford to put on a turbo, guages, ECU, radiator, intake, exhaust and IC and fuel components all at once? because you'll need all that by the time you want to change the turbo's.
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
