Curb Weight
Old Sep 3, 2001 | 01:04 PM
dcamcoTII's Avatar
Curb Weight
I have an 87T2 w/ power windows and a sunroof--no p/s or leather or pdl--what should my car weigh in at empty? How about if i remove my airpump, what does that weigh?
Old Sep 3, 2001 | 01:06 PM
dcamcoTII's Avatar
I also tossed the stock exhaust for full RB, that should make it lower.
Old Sep 3, 2001 | 05:23 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
dump the jack and spare in favor of a plug kit adn a air pump
ok I had to do that cause i havent found a 16" spare yet i cant get rid of the air pump but I heard it was like 20 lbs. AC weighs a lot if you dont mind sweating
Old Sep 3, 2001 | 06:06 PM
JerryLH3's Avatar
Rabbit hole specialist
Stock, the cars weighed roughly 2845 lbs.
Old Sep 3, 2001 | 09:19 PM
relvinnian's Avatar
Air pump..
...wieghs like 8-10 from the feel of it, definately not 20. A/C and power steering weigh alot b/c you remove alot of components (condensor, compressor, reciever/drier), and there is alot of metal hosing too...
-Brian
Old Sep 3, 2001 | 09:45 PM
Dyre's Avatar
Your Opinion is Wrong
The brackets for all the a/c and p/s stuff weights a TON too-
its insane.
Old Sep 3, 2001 | 10:17 PM
deadof_knight's Avatar
keep the ac man !
if not send it to me you sweat like a mad man in an rx7 Im hear to tell you in oklahoma i die in the summer with no ac in my rx7 my compressor is blown and i havent found the time or money to getit going since r12 is soooo high ! oh well
Old Sep 4, 2001 | 04:09 AM
relvinnian's Avatar
I don't know about yours, but my a/c and ps bracket wieghs like 3 lbs, it's alluminum. My air pump bracket is steal but it's only a curved "arm" that holds the pump, and weighs 3 lbs or so... but yeah removing ALL the minor stuff will eventually make an impact =)
-Brian
Old Sep 4, 2001 | 04:33 AM
Dyre's Avatar
Well, i havent taken off the stuff on my FC, but i have been helping my friend swap motors on his first gen, and i couldnt believe how heavy his a/c brackets where-
The only thing i've taken off my TII is the Airpump, and it was heavy too, so i figured my brakets would be heavy too-
my bad-
MILOS7
May 9, 2016 06:39 AM
