New Remanned installed, can't keep it running.
Old May 20, 2003 | 08:51 PM
ejmack1's Avatar
Lawn Ornament
With a little gas it starts and will stay running as long as I keep my foot on the gas. As soon as I let off it dies Any ideas what to check?
Old May 20, 2003 | 08:57 PM
mmonaco's Avatar
Part out my Car
fuel pressure! maybe a bad pump!
Old May 20, 2003 | 08:58 PM
mmonaco's Avatar
Part out my Car
are they stock injectors and fuel system?
Old May 20, 2003 | 09:01 PM
ejmack1's Avatar
Lawn Ornament
I took the TPS off when installing all my blockoff plates... could that have anything to do with it?
Old May 20, 2003 | 09:03 PM
Fritz Flynn's Avatar
All out Track Freak!
Re: New Remanned installed, can't keep it running.
EJ,
My guess is the primaries are clogged up. Good luck with it
Fritz
Old May 20, 2003 | 09:06 PM
YES If the throttle position was changed. May want to try resetting it. Check one of the rx7 web sites I'm sure there are some good tips on resetting it.
Old May 20, 2003 | 09:07 PM
ejmack1's Avatar
Lawn Ornament
Thanks fritz, I cant wait to see how the HKS front mount, Koyo Radiator, and rims perform lol.... you ****** part god!
Old May 20, 2003 | 09:11 PM
I think the fmic will make a big difference Just let me know if there's anything else you need
Old May 20, 2003 | 09:21 PM
ejmack1's Avatar
Lawn Ornament
Any other suggestions guys, my TPS is fine....
Old May 20, 2003 | 10:53 PM
ejmack1's Avatar
Lawn Ornament
ttt
Old May 21, 2003 | 12:38 AM
adjust Idle screw and see what happens.
Old May 21, 2003 | 10:37 AM
ejmack1's Avatar
Lawn Ornament
ttt
Old May 21, 2003 | 11:20 AM
paw140's Avatar
Does it run ok otherwise? You may just need to adjust the throttle stop and air screws.
Old May 21, 2003 | 11:37 AM
ejmack1's Avatar
Lawn Ornament
when i hold the RPMS aboe 1K it runs decently if i try to let them go below that it wants to die
Old May 21, 2003 | 12:33 PM
Mr Project's Avatar
Kinda sounds like a vacuum leak.... maybe double-check things, or have a friend keep it above 1k while you listen for leaks?
Old May 21, 2003 | 12:39 PM
ejmack1's Avatar
Lawn Ornament
could me removing the ISC have anything to do with this?
Old May 21, 2003 | 02:44 PM
paw140's Avatar
Yes... by removing that, the computer has no way to adjust the idle.
Old May 21, 2003 | 02:45 PM
paw140's Avatar
In my experience, vacuum leaks, unless they are very very bad, generally lead to a high idle.
Old May 21, 2003 | 03:39 PM
93BlackFD's Avatar
built my own engine
sounds like an unadjusted, thrown back in throttle cable...you know you can adjust that thing without screws, it's two nuts that control it's tension
Old May 21, 2003 | 04:01 PM
paw140's Avatar
How would a misadjusted throttle cable cause it to not idle? If anything, it would cause a high idle.
Old May 21, 2003 | 05:37 PM
mjw's Avatar
mjw
Go into the etc screen and turn off IDL/IGN control, don't worry about the ISC. I removed mine and it actually idles better than before, you just have to manually set your idle.. it takes a while tweaking here and there over time. It sounds like your throttle plates may be adjusted too far closed, open them up and let it idle a bit high and work it back down.. or back off the air bleed screw.
Old May 21, 2003 | 08:37 PM
ejmack1's Avatar
Lawn Ornament
got her runnin, just put the ISC back on....
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Skeeg
Sep 5, 2015 07:41 PM
vmerino
Sep 5, 2015 11:26 AM
