another problem
Old May 19, 2003 | 06:23 PM
another problem
first of all, i would like to thank everyone for their help on my car, through the swap, til, the present, but theres still yet another problem.
i have done a swap, from auto to manual, and its done, the car has a downpipe, and a BOV, i had codes 19, 30, 33, 39, and a mess up vacuum hose, all codes are now gone (thanks to yall) and the hose is fixed, im pulling no codes whatsoever now, heres the current and persistan problem:
car cranks fine, rough idle, than when i rev the car, and it get to about 2500 rpm's, it sputters, and cuts out bad, but never dies, and the check engine light blinks on, but than goes off, and im pulling no codes now, as i said before? what they heck could this be now?
i still dont have a driveshaft, so its still in the garage, where its been for about 6 weeks.
thanks
Old May 19, 2003 | 06:32 PM
xstacy7's Avatar
I love when things work
No Driveshaft...what the hell?!?
Old May 19, 2003 | 07:20 PM
did a swap, the driveshaft is on the way, come on now! i mentioned that bc i just wanted the readers of the post to know that i cant actually drive it right now, thanks
Old May 19, 2003 | 07:42 PM
Flyrx7's Avatar
Money Pit
Did you by chance reset the ECU?
Frank
Old May 19, 2003 | 08:13 PM
sure did several times, thanks though, anyone else?
Old May 19, 2003 | 08:52 PM
bump
Old May 19, 2003 | 08:56 PM
T88Rx7's Avatar
check your spark plugs, they might be fouled out
Old May 20, 2003 | 01:56 PM
good idea, some are on the way, anyone else?
Old May 20, 2003 | 01:57 PM
spark plugs were covered with some black sut, badly, i clean them, but did no good, can a plug look good and still be fouled?
Old May 20, 2003 | 02:18 PM
spurvo's Avatar
don't race, don't need to
Sounds to me like you might be flooded? Are you letting this engine warm up fully before you are shutting it off? Since you are not driving it around, you need to idle it for about 5 to 7 minutes to get the temps up fully before you shut off. If you are only starting it and running it a few minutes each time, you are just pooling fuel into the engine, ESPECIALLY if the ECU thinks the engine is cold and is running it's accelerated warmup fuel dump dance!
Look on this forum for flood fixes. Perhaps pulling the EGI fuse (t disable the fuel pump), pulling the plugs and turning it over for ten to twenty second spurts a few times to clear the fuel out of the combustion chambers?
Warm it each time you start it, or it WILL flood!
Old May 20, 2003 | 05:07 PM
did not think of that, i will try it spurvo, thanks, i will try that, but until then, anybody else got anything?
thanks
Old May 20, 2003 | 07:05 PM
well, i thought it might be flooded, took the two leading plugs out, the two bottome ones on each cyl, and unhooked the wires from the other two plugs, and removed the egi fuse, and turned it over for about 15 secs, 3 different times, i couldn't tell that anything had came out of the chamber, so i put the plugs back in, and i had the same symtoms!
it would rev fine, until about 2200 rpm's, and than it would sputter, and cough, like a lawn mower, and the check engine light will blink on, but not stay, and i could still increase the rpm's by giving it gas, but they power decreased, the engine noise grew weaker, but the rpms increased, only past 2200 rpms would it act up.
any more ideas, im lost, timing? plugs? what does this sound like!
thanks
Old May 20, 2003 | 07:27 PM
bump
Old May 20, 2003 | 07:45 PM
93BlackFD's Avatar
built my own engine
crank angle sensor?
Old May 20, 2003 | 07:49 PM
what is a crank angle sensor? i have no codes, and before i put it in my garage, i had no problems, it just sat there, for about 6 weeks, surely things wouldnt start going bad.
Old May 20, 2003 | 08:47 PM
bump
Old May 21, 2003 | 09:51 AM
anyone
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
