Broken Motor Mount Question
Old May 18, 2003 | 10:04 PM
whitet777's Avatar
While replacing my clutch, I saw my driver's side motor mount was split in half. That could explain the weird clicking noises I was hearind during autocrosses when I accelerated hard out of corners. Could that also explain why I have an oil leak in the oil pan vicinity?
I don't understand the whole thing about the motor mount being oil filled per http://www.scuderiaciriani.com/rx7/oil_pan_removal.html
Does this just mean that the stud that passes through the mount goes into the oil pan and that connection can leak? Can I replace the mount without draining the oil? Will the urethane mounts hold up to breakdown from oil leaks?
Any help would be appreciated.
Old May 18, 2003 | 10:43 PM
duboisr's Avatar
If you replace the motor mount you will not drain the oil pan in your face. A oil dampened motor mount has a pocket of oil inside it to stop the vibrations. You have an oil leak in that vicinity ,like all the other old pans ,they leak.
Old May 18, 2003 | 10:50 PM
whitet777's Avatar
So, you are saying the stock mount in my FD is not oil filled?
Old May 18, 2003 | 11:12 PM
reza's Avatar
not by engine oil...its like a gel mousepad...
Old May 27, 2003 | 08:48 AM
whitet777's Avatar
Does anyone know if I can replace the engine mount without removing the oil pan? Sounds like a dumb question I know, but I was worried about the oil seal around the bolts. I planned on putting permatex on the bolts, but just wanted to make sure I wasn't going to end up with a worse leaking oil pan by just replacing the engine mounts and not taking off the oil pan and re-sealing it.
Old May 27, 2003 | 08:56 AM
DamonB's Avatar
Yes. But you still have to jack up the motor to remove the mounts.
Old May 27, 2003 | 09:12 AM
whitet777's Avatar
No problem with jacking up the motor. Any advice on what to use on the bolts to seal?
