Hit the dyno today
Old May 17, 2003 | 01:23 PM
Lt. Dan's Avatar
Hit the dyno today
Mustang dyno
85 Mazda RX7 GS
stock port
racing beat air cleaner with K&N filter
MSD dual leading coil mod
racing beat header
Mindtrain exhaust
stock timing
stock fuel
108 hp @6750
not bad, gotta start playing with the fuel mixture and timing now....
Dan
Old May 17, 2003 | 03:18 PM
brianmcd's Avatar
Why'd you stop at 6750? can you upload the dyno sheet?
Old May 17, 2003 | 03:32 PM
abeomid's Avatar
I believe stock Carb falls off somewhere around there.
Old May 17, 2003 | 04:28 PM
FB II's Avatar
nope, another person on this forum and I made horsepower all the way up to 7800.
Old May 17, 2003 | 10:21 PM
Lt. Dan's Avatar
Like I said, I think there's more to be found with fuel and timing adjustments....
Dan
Old May 18, 2003 | 10:07 AM
onepointone's Avatar
i say what i want
mine made power all the way up to 7k (where i stopped), and it was still climbing. i have a stock carb. if i can find the dyno sheet, ill post it.
Old May 19, 2003 | 12:08 AM
KYPREO's Avatar
www.AusRotary.com
Stock carbs can run out of fuel at about 6500rpm without being modded, however, my 12A (stock port) still made peak power at 7800rpm with the stock carb. With the modded carb, it pulls above 8000rpm.
Great stuff - hope you get more once you play with the timing a little.
Old May 19, 2003 | 06:54 AM
inittab's Avatar
I read your email
My stock carb fell off at around 7k before I installed my Mallory Comp70 fuel pump. Now she pulls hard to at least 7800.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
