premix: valvoline 2cycle racing oil
Old May 14, 2003 | 05:06 PM
weaklink's Avatar
Resident Retard
whaddya think? is valvoline 2 cycle racing oil ok to use as premix? I feel better about it than the marine outboard oil I've been using. The valvoline's not synthetic though.
Old May 14, 2003 | 07:21 PM
onikageka's Avatar
Why are you pre-mixing 2 stroke racing oil into your gas? The 13B has provisions for oiling. And I've never really heard of a "seized" rotor due to inadequate lubrication.
Old May 14, 2003 | 07:30 PM
People use pre-mixes when removing the oil metering pump. (something that I plan to do when I turn mine to strickly track)
Old May 14, 2003 | 07:41 PM
j9fd3s's Avatar
Community Builder
that stuff works fine
mike
GoRacer's Avatar
Speed Mach Go Go Go
You should read the label or look it up online. Can't tell you if dyno or synthetic matters but you want a very clean burning oil (low ash). I've used marvels mystery but have since been using royal purple 2-stroke.
Old May 14, 2003 | 07:46 PM
weaklink's Avatar
Resident Retard
I still have the omp, but I am running an apex PFC, which may or may not control the pump adequately. I also have larger than stock injectors, and I have read that it is essential to use premix under these circumstances. My engine builder also advised me to use it. It's cheap insurance. I use to use MMO, but decided to go with a more purpose made product.
Old May 14, 2003 | 07:51 PM
Kento's Avatar
2/4 wheel cornering fiend
Just out of curiosity, what ratio are you guys pre-mixing at?
Old May 14, 2003 | 09:21 PM
weaklink's Avatar
Resident Retard
Not sure of the ratio, but I am now using 8oz for a full tank. Was using 4 oz at each fillup. Every 4th tank or so, I skip premix. My personal voodoo.
weaklink's Avatar
Resident Retard
BTW looked up the ash content on Valvoline website and it's listed as "nil".
Old May 14, 2003 | 09:57 PM
fdslave_g's Avatar
A capital FD barbie
8Oz? whoa! I use only 4Oz.
BTW I'm curious, what would happen if you mixed it in too much? or too little?
Old May 14, 2003 | 10:15 PM
GoRacer's Avatar
Speed Mach Go Go Go
I use 4-6 seconds worth. The MMO bottle had measurements on the side I noticed I poured 1oz/per sec. I think Pettit's site mentions 40z/tank but it should actually be 6oz/tank because we fill with 16gal's. I think I got that from the MMO bottle. It refers to a tank as 10gal's and 4oz/tank.
Zero ash on the Valvoline 2-stroke? I'll have to check wallmart to see if they sell it.
Old May 15, 2003 | 01:32 AM
skunks's Avatar
I'm a CF and poop smith
as long as it says TC-W3, its fine
Old May 15, 2003 | 07:21 AM
weaklink's Avatar
Resident Retard
I think the volume you use should be dictated by how modified the car is. TC-W3 is a spec for synth oils I believe, which the valvoline is not. I don't think Wal Mart carries it. They only carry marine oils (prob same things) and MMO. I noticed when using the marine oils that my car smelled like an outboard! The valvoline is formulated to be reduced smoke. I found it at Autozone while picking up some anti-seize for the plugs.
Old May 15, 2003 | 07:23 AM
weaklink's Avatar
Resident Retard
http://www.valvoline-technology.com/...9?OpenDocument
Old May 15, 2003 | 07:46 AM
PVerdieck's Avatar
Pettit says 4 oz. for normal driving, 8 oz. for racing applications.
Old May 15, 2003 | 08:26 AM
weaklink's Avatar
Resident Retard
my bad, tc-w3 is a spec by the national marine manufacturers assc. to certify marine two-cycle oils.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
sYnth.
Aug 19, 2015 06:27 PM
