Metal oil line to turbo... got a questions.
Old May 13, 2003 | 01:23 PM
ejmack1's Avatar
Lawn Ornament
Its the line that runs fromt he drivers side of the engine to the turbos... there is like and air hose that runs with it, what is taht for and where does it go?
Old May 13, 2003 | 01:26 PM
dubulup's Avatar
development
nope...
Old May 13, 2003 | 01:39 PM
ejmack1's Avatar
Lawn Ornament
why would it be going to the drivers side of the engine though?
Old May 13, 2003 | 01:45 PM
dubulup's Avatar
development
opps...I read too fast and thought too slow...
Old May 13, 2003 | 02:10 PM
spurvo's Avatar
don't race, don't need to
Yep, that's the one. It attaches to the drivers side of the engine right under the ear for the vacuum chamber just behind the alternator adjustment bracket. It runs under the entire mess on top of the engine to the turbos. The line that runs with it is from the oil filler tube to the primary turbo inlet. This allows oil gas and blowby to be burned off during boost conditions as the PCV valve is shut then.
Old May 13, 2003 | 02:33 PM
ejmack1's Avatar
Lawn Ornament
not the same one, this is a hard line attached to the oil line for the turbos.....
Old May 13, 2003 | 02:44 PM
Marshall's Avatar
The line from the filler tube is the one attached to the oil line.
Old May 13, 2003 | 07:05 PM
duboisr's Avatar
Correct , rubber to the filler thing to the tube in question ,then the tube goes to in front of the turbos ,to connect to the pri turbo intake elbow with a rubber hose .that is a vacuum signal to pull air from the lower motor , oil pan .
Old May 13, 2003 | 07:28 PM
ejmack1's Avatar
Lawn Ornament
ok cool thanks!
FD7KiD
15
Feb 26, 2021 10:12 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
