Heater problems
Old Aug 31, 2001 | 11:51 PM
momar's Avatar
Heater problems
The problem I have is that when I try to put the heat on it just blows normal air. Could this be that the heater doesn't work or some other problem. Any replies would be helpful.
'86 N/A Rx-7
Old Sep 4, 2001 | 08:51 AM
ltolisano's Avatar
I guess by normal air you mean cool air?? It could be several things - most likely you need to resolder the logicon. I had the same problem (except I was stuck with only hot air!). This happens because poor solder joints prevent the cold/hot selector from being set properly. The other possibility is that the air mix motor is shot.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
Hipsiguy
Sep 14, 2015 05:25 PM
risingsunroof82
Sep 7, 2015 01:11 PM
