How to tell if its a remaned motor?
Old May 9, 2003 | 06:50 PM
wicked sol's Avatar
Is there any way to tell if you have a remaned motor by looking at it? It there any id numbers to check or anything?
Old May 9, 2003 | 08:24 PM
xstacy7's Avatar
I love when things work
the vin numbers on the front housing on the engine, those should be the same as the last numbers/letters on your VIN # (if i remember correctly) if not...well then you have yourself a reman.
Old May 9, 2003 | 08:36 PM
jpandes's Avatar
Check to see if the motor has been painted. That's a tell-tale sign that the motor is a reman. The paint color could silver or grey so look closely.
Old May 9, 2003 | 08:54 PM
suprfast's Avatar
i was told that the motors did not have VIN numbers. am i wrong? painted housings
kris
Old May 9, 2003 | 09:20 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
I'd imagine unless it's filed, it had to have come from somewhere, so it would have the VIN from where ever it came from.
Old May 9, 2003 | 09:43 PM
turbojeff's Avatar
Do it right, do it once
As far as I know motors don't have a VIN, they have a engine number. Go to Mazda with your VIN and ask for a warranty report. This warranty report will show your car's original engine number as well as any work done under warranty or recall.
jpandes has it pretty much correct. If the water pump housing (not water pump), water neck have been painted silver it is probably a reman. To be absolutely sure there is actually a aluminum tag glued to the motor. Unfortunately you can't see that tag with the motor installed and complete. It hides behind the pressure tank down by the PS and AC pumps.
Old May 10, 2003 | 02:19 AM
neevosh's Avatar
The Dude Abides
I believe on the front cover, next to the CAS, is a blue tag. I think it'll say remanufactued on it.
Old May 11, 2003 | 08:08 PM
boost-in-rx7s93's Avatar
If the motor is pulled take the flywheel off and see if the 16 bolts that hold teh housings together are red if they are IT IS A REMAN! that is the tail tail sign!
joe
Old May 11, 2003 | 08:55 PM
legal-z's Avatar
12th son of the lama
if the motor was a mazda reman, it will have a sticker on the oil pan. i don't know how long the sticker would stay on but mine has 12k on the motor and it's still there.
Old May 12, 2003 | 07:18 AM
paw140's Avatar
Jeff is correct, the engine number on the front cover does not match the VIN number. You need to contact the dealer with your VIN and they can give you the original engine number. Unfortunately, you have to remove the alternator to see the number.
Old May 12, 2003 | 10:13 PM
fdeeznutz's Avatar
White is tight
you know you have a mazda reman if it leaks like a siv, about a quart a month, pieces of ****
Old May 12, 2003 | 11:34 PM
TwinTriangles's Avatar
What's an RX-7 ?
Nice one fdeeznuts! My buddy got a front clip from japan that had 60k miles on it originally I think and had clearly been rebuilt, it had silicone sealing everywhere, the rotor housings, oil pan, everything...
Old May 13, 2003 | 10:03 AM
fd3virgin's Avatar
yeah, that. mine has a blue tag.
slachta1
Sep 9, 2015 07:36 AM
ls1swap
15
Sep 8, 2015 05:30 PM
doritoloco
Sep 5, 2015 12:41 PM
