Exhaust presure in oil chamber
After a engine rebuild, when getting turbo boost i get a exhaust presure in the oil pan. And the oil check pin hops out and oil flushes out og the hole.
When opening the oil filler cap and reving the engine so that i get boost presure, exhaust comes out of the oil filler hole.
Ive looked over the vacume hoses and cant find a problem. What i want to now is wich hoses/cables might have exhaust pressure. And maybe some one have pictures of rebuilding there engine. So that i can look at all hoses and so on.
The car goes terebily, when accelerating and getting boost there comes blue smoke out of the exhaust pipe.
The car is a 92 FD RX7 Japan spec.
Folowing mods
Greedy air intake.
Greedy front mount intercooler
Greedy Dump valve.
I hope someone can help.
Here's a vacume chart. Any sugestions?
http://www.apneablue.com/rx7/photos/...colorhoses.jpg
JT Pedersen
Folowing mods
Greedy air intake.
Greedy Dump valve.
JT Pedersen
exhaust pressure? the only thing i know of is getting compression to the oil by bad side seals. you should also have fuel in your gas. not sure how you would pressurize the oil with exhaust.
Trending Topics
Thanks for your imput. Im realy afraid of an answer like that again. The strain of stripping the motor again is not good.
Im hoping for it to be the turbo's but time will tell.
JT
JT
