Smog Help
Old May 9, 2003 | 12:31 AM
xthaboy17's Avatar
Smog Help
Ok i finally got a main cat to put on my car. You guys think I dont put air pump in it woont pass smog. Visual i know it wont but i got someone to overlook it. Any suggustions would help. Thanks.
Old May 9, 2003 | 10:59 AM
maxpesce's Avatar
Ex fd *****
Probably WON'T pass a sniffer w/o the air pump - the Cat needs extra air to catalise (Burn) the Carbon-monoxide (co) to Carbon-dioxide (co2) and the unburned hydrocarbons (HC) to water (h2o) and co2
so you can see the catalyst needs a LOT of Oxygen (o2) (air = 14% o2) to work correctly.
Old May 9, 2003 | 11:05 AM
rynberg's Avatar
You will need the air pump hooked up to "legitimately" pass the test. Also make sure your car is completely warmed up -- as in pull into the smog station right after doing some hard freeway driving...
Old May 9, 2003 | 12:55 PM
xthaboy17's Avatar
Thanks guys
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
