urgent help needed (need to kill skyline)
Old May 8, 2003 | 10:46 PM
okay sorry, but i'm really confused about this connection. i don't know what it is. it's a greyish color. i need to know what it does. i have a non-seq. turbo's. it's like a little up and to the right of the intakes. when i connect it like the thing inside a pulley spins. and when i drive with it i get a LOOOOOOOT of backfire. i'll try to look for a pic but can someone help me out?
but yeah cuz i'mma race a skyline tomorrow -.-
Old May 8, 2003 | 10:53 PM
and like the interior of the greyish connections is like orangish....-.- SOMEONE HELP ME
Old May 8, 2003 | 10:54 PM
oh and i would like to know if i should connect it when i race or not...
Old May 8, 2003 | 10:56 PM
Dude! You need to learn how to write so that the members can understand you. Are you an F.O.B?
Old May 8, 2003 | 10:58 PM
hahahah because i'm AN FOB huh? dumbass i'm just kind of in a rush sorry about that people.
Old May 8, 2003 | 11:00 PM
Okay, explain it clearly so that I can help you. Use full wording.
Old May 8, 2003 | 11:26 PM
even better here's a pic...
Old May 8, 2003 | 11:27 PM
but yeah like i said i'm running non-sequential turbo's and i'm confused as to what that is and does.
Old May 8, 2003 | 11:31 PM
It's the air pump connector... I run with mine unplugged all the time. It's not needed if you have a midpipe.
Old May 8, 2003 | 11:32 PM
crazyrx7's Avatar
Big Daddy!!!
That connector is for you air pump. If you are running no cats on your car then you can just disconnect the plug, but if you are running a cat instead of a mid pipe then I would suggest you leave it plugged in so that you don't clog your cat.
R.K.
Old May 8, 2003 | 11:33 PM
duboisr's Avatar
AIR pump clutch connector.
I ran without mine connected for about 1000 miles because the pump failed. I was going to replace the cat with a midpipe (done now) so never replaced the air pump. When I was done, the cat wasn't clogged yet. It takes a while still, just significantly shorter I think...
Old May 9, 2003 | 12:26 AM
it's weird though because when i connect it i get a lot of misfires. and i just feel quicker acceleration.
Old May 9, 2003 | 12:30 AM
Zoomspeed's Avatar
shoudlnt' really feel a difference. its only on ina short RPM range.
Old May 9, 2003 | 01:08 AM
thanks you guys...haha and to Koolzero1 sorry about my earlier comment i take that back. i'm the idiot. btw welcome to the forum!
Snoopy FD
Aug 19, 2015 03:40 AM
