Bad Coil ??
Old Aug 31, 2001 | 09:09 AM
P.O.S. Racing's Avatar
Question Bad Coil ??
How do you determine if you have a bad coil? What are tell tale signs?
The Haynes manual states that they can be tested as follows , “Using an ohmmeter, check the resistance of the coil. Do this by touching the probes of the ohmmeter to both the positive and negative terminals of the coils. Check each separately. The primary resistance should be 1.35 plus or minus 10% ohms for both coils.”
Thanks,
Old Aug 31, 2001 | 09:41 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
That's how I checked my old coils.
Not sure about the exact resistance off the top of my head, but I used the haynes manual specs as well. (I tested my set when everything was working fine) and was within that spec.
Old Aug 31, 2001 | 09:54 AM
But how do you tell if you have a bad coil? Are there tell tale signs?
Old Aug 31, 2001 | 11:44 AM
Pittdp's Avatar
I have always checked at night by taking one wire off and pulling it away about an inch and having someone crank the engine, If it looks strong your good but if it looks like there is very little spark going threw go get a new one, Repeat on second coil when done just make sure to plug the wire back into the first one before you do it.
rgordon1979
40
Mar 15, 2022 12:04 PM
The1Sun
Sep 15, 2015 04:45 PM
windom
Sep 11, 2015 04:48 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
