Throw out Bearing?
Old May 8, 2003 | 02:25 PM
matty's Avatar
Throw out Bearing?
What is a throw out bearing?
What are the symptons of a worn throw out bearing?
Are these replaced when upgrading the clutch?
Old May 8, 2003 | 02:34 PM
rotary-tt's Avatar
2 babies - no back seats
Rattling sound with the clutch out. Most places will make you buy them when they put a new clutch in.
NewbernD's Avatar
Tequila? ..it's like beer
It's a bearing that rides on the throw-out fork of the transmission. It's what lets your foot put pressure on the spinning clutch in order to disengage it.
When it's worn, or the bearings have gone dry, it'll make noise when you push and hold the clutch in. Could be a grinding noise, could be a squealing noise..
There's also a spring that holds it to the fork. If that breaks, you could have intermittent problems like trouble putting the car into gear, the clutch pedal might not "feel right."
Yes, it should be replaced if your replacing the clutch due to wear. Throw-out bearing, rear main seal, flywheel surface, pilot bearing & seal too.
Got problems?
Old May 8, 2003 | 02:55 PM
matty's Avatar
well i am upgrading clutch and flywheel ala SR internet special...9.5 lb flywheel and act street strip clutch...do i need to buy anything else?
Currently i have slippage..the clutch isnt old it just cant hold the power my fd makes now. I asked the question about the throw out bearing b/c i read that a sign of a worn bearing is a rattling noise when the clutch is out and you are in nuetral..i have this noise but no other problems. The rattling isnt bad but it is audible...is this normal...?
Old May 8, 2003 | 02:57 PM
matty's Avatar
scroll down this page...does this package have everything i need to replace...
http://www.srmotorsports.com/sr93clch.html
Old May 8, 2003 | 02:59 PM
matty's Avatar
oppss...also tell me about these pressure plates...is that part of a clutch package...should i upgrade this too?
I know nothing about clutches and related parts so please fell free to enlighten me!
Old May 8, 2003 | 03:28 PM
xstacy7's Avatar
I love when things work
you need to get a new pressure plate along with a new clutch
Old May 8, 2003 | 03:33 PM
mjw's Avatar
mjw
The SR special comes with everything you need: pressure plate, clutch disc, throwout bearing, release bearing, alignment tool, flywheel, counterweight.. everything but the rear main seal and a SS clutch line. Replace the rear main seal when you are in there for sure, I didn't do mine and it is leaking a bit now.. I am still kicking myself for not heeding other people's advice here.
Matt
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Vartok
16
Oct 8, 2015 04:49 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
