Normal Idle RPM
Old May 7, 2003 | 08:03 PM
The_7's Avatar
Registered Piston Eater
Normal Idle RPM
What is the normal idle rpm for an 83 rx7? i think mine might be idling way to high.
Old May 7, 2003 | 08:08 PM
wwilliam54's Avatar
it WILL run
750
Old May 7, 2003 | 08:11 PM
FB II's Avatar
is it still 750 if you have a full out header/exhaust setup? cause mine idles smooth down to about 1000 maybe 900. any lower and it wants to die.
-zac
Old May 7, 2003 | 08:22 PM
The_7's Avatar
holy **** mine idles at 1500. well its partially because of the pedal linkage if i pull it back with my foot it drops to 1000 but wont go below that.
Old May 7, 2003 | 08:27 PM
wwilliam54's Avatar
it WILL run
-zac
i dont know about a rotory, but on a piston enine the drop in backpressure would make you shift the idle up
anything that lowers bottom end torque makes you have to raise the idle
Old May 7, 2003 | 09:35 PM
FB II's Avatar
makes sense. nice
Old May 7, 2003 | 09:39 PM
brianmcd's Avatar
i just installed my exhaust, and now my car is idling really low. i tried messing with the screw but i can't get it any higher than like 600-700, and it is pulsating. But mine used to idle at like 800-850 before I got my full exhaust.
Old May 7, 2003 | 10:57 PM
bliffle's Avatar
The 83 idles so smoothly at 700 you can't tell it's running. The 85 is almost as good, but not quite so quiet.
B
Old May 8, 2003 | 07:49 AM
OtakuRX's Avatar
The Rotorheaded Geek
jeez, mine was idling smoothly at like 500 before I put it away and started taring it down
Old May 8, 2003 | 09:36 AM
Metallic_rock's Avatar
Ride 'n Style
maybe the tach is off? I remember talking to someone who had a tach that was off... it said 1200 when it was at 800, so he adjusted it down to read 800 and made it 400... it ran, but ran like crap.
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
