Install 99' Engine
Old May 5, 2003 | 07:00 PM
jack pang's Avatar
Install 99' Engine
I'm blown the motor. I'm own a 93 gen but i want to reinstall 99' engine is it o.k.? what other parts i need install too.
Old May 5, 2003 | 07:35 PM
9413Btt's Avatar
Yes it is ok. Do a search, someone in this forum has done it before.
Old May 5, 2003 | 07:51 PM
vudoodoodoo's Avatar
Should be OK. Better than a 93 engine. They updated it a bit and got rid of the rat's nest. 99 spec turbo too... = P~~
Old May 7, 2003 | 02:00 AM
jack pang's Avatar
How about the computer should update or not?
Old May 7, 2003 | 02:07 AM
SpiritR's Avatar
Yes you need a computer...
Old May 7, 2003 | 08:38 AM
SaulV's Avatar
OG
Just contact Rotaryworks.com or rotaryworks on aol IM and they have them for sale...complete from turbos and harnesses
Old May 7, 2003 | 09:41 AM
Crash's Avatar
ON problme you'll run into isthe the harness wants to come in on the drivers side of your 93 right at your feet. Sure you can get around it some how but may be fun trying
Old May 7, 2003 | 09:48 PM
9413Btt's Avatar
99+ spec ECU is diff from the 93 ECU
Old May 8, 2003 | 10:29 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
by my understanding, the 99 spec ecu is different in programming (because of the turbos).. but the wiring is the same..
Old May 8, 2003 | 11:57 AM
Cihuuy's Avatar
i think the 99 spec ecu is 16 bit/32bit... not much changes in the engine... so y not get an older engine and the 99 spec turbo?? doesnt that save more $$$?
Old May 9, 2003 | 08:09 PM
SpiritR's Avatar
99 spec is 32 bit. Wiring and plug are NOT the same.
yeah not much of anything changes with the engine- just newer.
Old May 9, 2003 | 08:20 PM
xstacy7's Avatar
I love when things work
if he is in Hong Kong doesn't he have a right hand drive anyway?
Old May 9, 2003 | 08:47 PM
Little 7's Avatar
I believed Hong Kong mechanic know how to swap engine in cheap labor cost. Don't worry on the swap's stuff, just find a 99's engine is difficult
befarrer
Aug 14, 2015 04:18 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
