Help - FB Susp. Tech 1 1/8" sway bar install problems
Old May 4, 2003 | 10:02 PM
Chrisman1969's Avatar
I am installing suspension techniques big sway bar. The instuctions say to "mount the anti-swaybar to the vehicle using the factory bushing brackets."
The problem is that the brackets are to small or Im not smart enough to figure out how to use them. Also the "tension compression rod assembley" hole that the sway bar goes through seems small for this big sway bar.... do I just dremmel it to a larger diameter?
Please help.
thanks,
chris
Old May 4, 2003 | 10:48 PM
pics of the front mount....
Here are a couple of pics... I think I may have the wrong bushings....
Help!!!!!!
Has anyone installed a ST sway on their FB???
Old May 4, 2003 | 10:55 PM
Help!!!!!!
Old May 5, 2003 | 12:02 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
looks right bushing to me.
i have a ST 1 1/8" sway bar in my 81 and I love it.
Had to take the front brackets off the front end. You know, the two brackets that the sway bar slide thru. bitch to get off. Besides that, it was simple bolt in.
no grinding or dremel required
Old May 5, 2003 | 12:03 AM
DriveFast7's Avatar
you know, those bushings doo look too tall for their brackets.....
Old May 5, 2003 | 12:21 AM
Manntis's Avatar
add to cart
they compress as you tighten the bracket to the frame - but not that much!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
MazdaAspec
Sep 9, 2015 02:04 PM
82streetracer
Aug 23, 2015 09:28 AM
need RX7
11
Aug 19, 2015 08:27 AM
