Temps keep Climbing??
Old May 4, 2003 | 11:10 AM
scottie's Avatar
Hi everyone! Just installed the Greddy 2 row fmic and the water temps just keep climbing when I dont have the fans on. Seems I have to keep the fans on all the time. When I do that it stays 80C-85C but if I turn them off it just keeps climbing and climbing!! Does anyone else have this problem? I followed the directions exactly (standing up A/C and radiator). I am running a fluydine radiator and Evans Coolant. Anyways what can I do to fix this? Even on the highway it will climb and climb. Any suggestions would be great! I searched and seems people dont have to run their fans all the time. Please help!
-scott
Old May 4, 2003 | 02:13 PM
skunks's Avatar
I'm a CF and poop smith
Bwahahahahahahhaaha hahahahaha hahahaha
how long have you owned a fd much less any other car??? If you dont know to keep the fans on (especially with a FMIC), that's pretty sad (especially for speeds which are under the tripple digits region). Common sence is not as common as it seems I guess...
Old May 4, 2003 | 07:04 PM
scottie's Avatar
Well I guess you must excuse my stupidity. For your information I had the M2 smic and when I would start moving i would NOT HAVE TO KEEP THE FANS ON and the temps would stay below 90C. I have owned my car for about a year and have never had a problem with the temps climbing. Jeeeezz I wasnt asking for a smart reply I just wanted to know if people have come up with solutions to getting more air to the radiator with a FMIC in which i dont have to keep the fans going all the time. Thanks for adding something to my post of no value.
Old May 4, 2003 | 07:17 PM
93BlackFD's Avatar
built my own engine
keep your fans on all the time or buy the duct to prevent air from flying over the radiator
Old May 4, 2003 | 08:06 PM
vudoodoodoo's Avatar
Well it's normal for the car to run a bit hotter with an FMIC. It IS blocking the radiator. Just keep the fans running all the time. Have a heat shield so all the heat from the radiator does not flow to the intake.
Old May 5, 2003 | 02:25 AM
skunks's Avatar
people like you are why fds explode or melt down haha
Keep on leaving your fans on and be sure to let us know what hte results are, i cant wait
Old May 5, 2003 | 06:54 AM
Garrett's Avatar
"people like you” Listen you yourself. The same could be said about you in the connotation of discouraging a fellow RX-7 owner. You need to quit this immature feedback.
FDs don't explode or melt. Unless you have a gas leak or engine fire. They detonate or the coolant seals start leaking. If you are going to be a smart-*** get the jargon of your RX-7 lexicon straight.
He is monitoring his car, BTW. These vehicles require this on a constant basis. He is well aware of its state (temps etc). I think your problem with it has more to with your arrogance than his question.
Personally, I would not expect you would have to leave the fans on all the time with him having Evans coolant and a fluidyne.
And damn, I thought you were younger than me. I guess a lot has to be said for wisdom rather than age. You sound more like a Honda-Ricer with something to prove. We (RX-7 owners) are a bit above this, don't you think?
Garrett
Ps. Learn how to spell common sense please.
Old May 5, 2003 | 09:14 AM
Hey Skunk...think you're a kick-*** mechanic or something? who the hell you think you are to ridicule someone asking for advise??? Stay out of the sun because it's starting to affect you. BTW, maybe "scottie"
doesn't have the answer or knowledge to lower his radiator temps but at lease he's educated...He knows how to spell, unlike yourself.....BBBABAHBAHAABBAAHBHABAHAAH (wtf is that) I give you 3 free advise. Grow-up, Stop insulting people and do yourself a favor and buy "HOOK ON PHONICS"
Old May 5, 2003 | 09:28 AM
Kiflin's Avatar
Someone needs to close this thread, its out of control...
But anywho, yes, a fmic will be slightly hotter than a smic, especially if your running it hard.
Old May 5, 2003 | 10:01 AM
Pedestrian X's Avatar
SpAz!
wow, im on teh first gen forums and never really come in here btu im bored and thought id check it out and this is the frist thread i see. sorta dissapointed.
Old May 5, 2003 | 02:32 PM
Garrett's Avatar
Read more than one post before you come to a conclusion. Don't base your disappointment on this post. Skunks disappointed me also.
Old May 5, 2003 | 02:38 PM
Astro's Avatar
which duct are you reffering to?
Old May 5, 2003 | 02:46 PM
93vrfd3s's Avatar
HOOAH!!
Scottie, I put the M2 Large SMIC in my car and I began to see increased temps at idle. Where I used to be at 87C during idle I am now well above 95C upwards of 99C. I am a bit worried and run my fan. When I am crusing I stay at 87C. I might try flushing my system and putting in some water wetter and see if I get better temps. Of course, I may have to work with the duct that came with my M2 to ensure there is no leakage of hot air back to the radiator (I too am running an SR Motorsports/Fluidyne) radiator.
Old May 5, 2003 | 08:02 PM
scottie's Avatar
For all those who replied trying to help me I greatly appreciate it and thank you for contributing to the cohesiveness thats unique to the Rotary community. Anyways I made a steel scoop that goes from the bottom of my FMIC to the radiator forcing air upward. I had my friend weld some brackets on and I tapped a new hole on the passenger side to make it fit perfectly. I will post pics & the parts used if anyone is interested. This is only for the Greddy as the others seem to have the radiator fitting directly behind the intercooler (i.e. Apexi, Blitz). This might work for the HKS as it sits in front of the engine bay. Thanks again guys.
-scott
Old May 6, 2003 | 12:17 AM
skunks's Avatar
newbie fd owners are so funny!!!
Newbies unite!
Old May 6, 2003 | 12:41 AM
Please someone close this thread it started stinking..
Old May 6, 2003 | 01:28 AM
curlybillbrosie's Avatar
skunks, you are a ******* moron. someone should shave and squeeze you until YOU pee, asslicker.
Old May 6, 2003 | 03:06 AM
Garrett's Avatar
Yeah, skunks is pretty much the fallacy of this thread.
Old May 6, 2003 | 08:07 AM
Na, he's just a fairy...he masterbates when on the forum....
Old May 6, 2003 | 10:19 AM
jspecracer7's Avatar
1JZ powered
-scott
I had this problem recently. Thought it was caused by a bunch of things. Turns out that one of my fan relay's was burnt out, causing me to run ONLY in low setting. Now that I have the relay replaced, when cruising, I can watch the temps go DOWN.
Old May 6, 2003 | 12:43 PM
Nathan Kwok's Avatar
The stock computer doesn't turn the fans on until 221F, which is 105C. Now, with your mods you shouldn't have a stock computer, but a "chipped" or piggyback fuel computer should do the same thing. If you have PFC or Haltech or other standalone system, then you can set the fans to turn on whenever you want. The bottom line is, as long as the temps will stay down with the fans on, just make sure the comupter turns them on at 105C or below and you are fine. If you aren't comfortable with running around at 105C you can rig up the fan mod or something else to turn them on earlier, but using Evans running at 105C is perfectly fine, just relax and let the computer do all the work. Your problem is the FMIC blocks airflow into the radiator so you'll need something extra to pull air through it and keep things cool, not really much you can do about it.
Old May 6, 2003 | 12:50 PM
Mikey's Avatar
you are an idiot!
musker
Oct 1, 2015 05:58 PM
subeone
Sep 24, 2015 09:58 PM
