LSD(how much power)
Old May 1, 2003 | 04:48 PM
Erdin's Avatar
Water Injection Specialist
Question LSD(how much power)
hi there
can anybody tell me how much power the stended limited slip differantial can take befor a up grade is needed i hope to run 500rwhp.
regards
Erdin
Old May 1, 2003 | 05:48 PM
mynamegotjacked's Avatar
At those power levels even an upgraded diff could break. Not to mention the diff housing...axles...etc.
Old May 1, 2003 | 06:51 PM
Erdin's Avatar
so what will have to be done can u get upgraded diff housings and axles or is it just down to luck.
Old May 1, 2003 | 09:32 PM
maxcooper's Avatar
WWFSMD
If you aren't doing drag launches, the stock diff seems to hold up fine for most people. I would guess that 500RWHP wouldn't necessarily kill it unless you are doing drag launches. Then again, I guess anyone with 500RWHP is probably looking to drag, so an upgrade might be required.
-Max
Old May 2, 2003 | 12:37 PM
Erdin's Avatar
What does everbody think of the Kaaz 1.5 lSD will it do the Job.
Regards
erdin
Old May 2, 2003 | 04:18 PM
c00lduke's Avatar
I've heard great things about it, dealing with the beating it can take but the only down side i would see is the extra noise thst goes along with clutch type LSD. Thats why i'll be looking for something different.
Thanks
~Luke
Old Jul 7, 2003 | 01:47 PM
RX-Racer's Avatar
Aoohh!!!
The kaaz LSD is a good investment. The chattering cOOlduke is talking about is the downside but can be fixed with a LSD additive located at any ford/gm dealer.
Jp
Old Jul 7, 2003 | 02:02 PM
BigIslandSevens's Avatar
the Kazz is awsome. i put it in after breaking the stock POS. The noise is hardly noticable. If your that picky you shouldn't have an FD. It only chatters at low speed parking lot type turns(driveway etc..)The 1.5 is plenty for street driving, the 2.0 will cause a bit of push in wet conditions espeacially. a good lsd oil and additive as RX-racer stated will help the noise and chatter. It will probably be the last Diff. you buy!!(you'll just break other things!!! LOL!!) good luck and have fun driving in figure 8's for 30 mins.!!
Old Jul 7, 2003 | 02:06 PM
forgot to add that my power output was around 405 rwhp. tuned at XS. T78 single kit etc..
Old Jul 7, 2003 | 03:36 PM
Erdin's Avatar
thanks every one i think iam gona go ahead and get the kaaz.
Thanks every one.
Old Jul 7, 2003 | 04:40 PM
vosko's Avatar
Just Call Me Terminator!
i have a stock new TII clutch type diff. its just as quiet as the torsen and has held up to all my abuse and approx 500hp!
Old Jul 7, 2003 | 04:52 PM
Mahjik's Avatar
Mr. Links
Arrow
You might also want to check this thread:
https://www.rx7club.com/forum/showth...hreadid=191383
