Which way clock or counter clock? Sorry for stupid question
Old Apr 28, 2003 | 07:18 PM
Jodoolin's Avatar
May have carbon lock. After squirting in MMO or ATF and facing the front of engine, I assume a counter clockwise turn on the eccentic shaft will rotate the rotors in a reverse direction. Am I correct?
Old Apr 28, 2003 | 07:21 PM
13bpower's Avatar
s4 for life
If you are standing infront of the car.... looking at the front of the engine.... the rotors spin clockwise. Spining them counterclock wise from this view would make them go backwards, which I have heard is a bad thing.
Old Apr 28, 2003 | 07:30 PM
Jodoolin's Avatar
Having searched thru a zillion posts the best comments I read suggest that once MMO or ATF is squirted several easy attempts over a few days to rotate the rotors in reverse might help break the particle(s) causing the seize (if it is indeed a lock and not jammed seal). Rotating in normal forward spinn could actually jam it in harded and score the facing. Make sense?
Old Apr 28, 2003 | 08:28 PM
skyypilot's Avatar
NO. You have it backwards! Virtually every engine including this one turns COUNTERCLOCKWISE viewed this way (including aircraft without gear reduction). Turning it clockwise is backwards!!!!!
Old Apr 28, 2003 | 08:58 PM
HAILERS's Avatar
HAILERS
3bpower got it right. He explained how he is viewing the engine looking from front to rear. The engine turns clockwise if viewed like that. But it's cackhanded if looked from the drivers seat.
_Tones_
May 25, 2021 05:37 AM
13
Jan 9, 2018 11:19 AM
msilvia
15
Sep 11, 2015 12:13 PM
Nosferatu
Sep 5, 2015 02:13 PM
