Trasmission noise?
Old Apr 28, 2003 | 12:36 PM
Kai's Avatar
Kai
Rotorphile.
Trasmission noise?
Just last night when I got back home, I parallel parked my car like normal, but when I was settling into the spot I heard this weird noise coming from the transmission. I hear the noise when the clutch is pushed down, and the car is in gear, it sounds like a squeaky shopping cart wheel (bad bearing somewhere?) The noise goes away when the car is put in neutral. Any thoughts are appreciated. Thanks!
Old Apr 28, 2003 | 01:03 PM
RyosukeTakahashi's Avatar
well the same thing happened to me, whenever I pushed the clutch pedal in, it would sound like a rattling thing. IN nuetral its fine. If you have problems downshifting as well (i.e. grinds) then its a worn out release bearing. When we took mine out it was like a skateboard bearing, one trun and it kept spining.
Old Apr 28, 2003 | 02:07 PM
SureShot's Avatar
Seduced by the DARK SIDE
Noise with the tranny in gear and the car not moving can't be from the tranny.
It has to be in the clutch/release bearing/pilot bearing area..
Old Apr 28, 2003 | 02:55 PM
Turbonut's Avatar
Push clutch pedal down just slightly to remove freeplay. If noise appears throw out bearing. If no noise, push to floor, if noise appears, pilot bearing.
Old Apr 28, 2003 | 05:38 PM
Kai's Avatar
Kai
Rotorphile.
Ok, thanks. I drove it today, and it makes noise driving around too. I was just about to sell this car for another RX, and the resale value is dropping every day
Old Apr 28, 2003 | 06:18 PM
SleeperZzZ's Avatar
could be u-joint, my car does it when going in reverse, when lightly accelerating, and when i first let off the gas, i know it cant be my pilot or throw out, beacuse i changed my clutch last week
Old Apr 29, 2003 | 02:27 PM
SureShot's Avatar
Let's try this again.
Noise with the tranny in gear and the car not moving can't be from the tranny or anywhere after it.
It could be something loose in the exhaust.
Maybe look around up front. It could be something simple around the belts & pullies.
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
