finally racecar pics...
Old Apr 28, 2003 | 01:10 AM
mperformance's Avatar
look!
Old Apr 28, 2003 | 01:14 AM
luiml73's Avatar
Rotary Powered Boobies
car looks nice, but we need closer pics. Interior looks sweet please post more pics.
Old Apr 28, 2003 | 01:17 AM
u asked here ya go...
Old Apr 28, 2003 | 01:22 AM
side...
I don't have many interior shots but the best part is the engine...yet no pics!
Let me see if I get some more.
Old Apr 28, 2003 | 01:23 AM
TheTwinTurboRX-7's Avatar
looks sweet dude
I like it
Old Apr 28, 2003 | 01:29 AM
thanks...
GUYS again wish me luck, my next race is next weekend. My second race.
first time ended up in 5th...stockported 12a, running with rear drum brakes, no LSD.
I have now a new 12a engine. Has a MONSTER EXTENDED port and huge exhaust ports, mindtrain stage III header, bad thing is am missing a side seal and have yet to close the engine up. I shooting for 200hp and that should put me in first place with some agressive driving.
Old Apr 28, 2003 | 01:38 AM
a little action...
Old Apr 28, 2003 | 02:44 AM
might I ask where you are located??
good luck, hope you get the motor back together in time!
Old Apr 28, 2003 | 05:17 AM
Amagi82's Avatar
50+mpg, woo!
Wooo! RX-7 racecars rule keep up the good work!
Old Apr 28, 2003 | 12:32 PM
Rotortuner's Avatar
Undercover
What kind of rims are those? And also I like the decal on the hood what does it say?
CJG
Old Apr 28, 2003 | 01:05 PM
The wheels are American Racing Libre wheels 110mm, 13x7 I'm running street tires in 215/50/13 size. I need to get some stockers so I can run Proxes Ra1 in 13s.
The decal on the hood is basically a cut view of the internals, a housing and a rotor. My GF copied an avatar in this same forum and we made a logo out of it.
I'm in Panama City, Panama
thanks
..and yes, rx7s rule!!!
MOD list:
45DCOE weber on lake city mani, extremely tuned
stockport 12a 168,000 miles, like new compression
no interior except for dash
no pwr, no a/c
magnecore 10mm sparkplugs
8EVG NGK sparplugs
cut strut towers bolt holes, no camber plates -3 deg camber
peejay's cable strut to engine brace
custom hybrid rubber/teflon engine mounts
back to mechanical fan
hawks HP+ pads front
rear brake drums- stockers from non gsl, gsl rear BLEW up
open diff
mindtrain header w/thermo wrap
no side windows or motors
relocated battery behind pss. side
no pass. seat
RCI 5 point harness
RCI window net
custom 6 pt roll cage
2.5 " exhaust to Greedy 3-5" N1 SS street muffler
cut rear coils
monroe cheap shocks back
Gabriel cheap struts frt
rear shock tower bar holding top mounts
215/50/13 street tires toyo/ yokohama
no rear sway bar
as you can see very cheap cheap race car...but it works...
Old Apr 28, 2003 | 01:29 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
what do you meen by this i have never seen a rear strut tower bar for the 7.
Old Apr 28, 2003 | 01:54 PM
I made this one last night...maybe useless but might work. I kept the whole rear suspension loose but added this to prevent some chassis flex
basically a bar going across the top shock towers.
Forget to mention I have some weird spring rates, I went with stock rear springs (very soft) and a set of modified integra race springs up frt. Around 300lbs/in. Cost me $20.00 pair.
Old May 13, 2003 | 09:21 PM
onepointone's Avatar
i say what i want
is there anyway i can get pictures of that cage? how much did it run you? is it welded in or bolted in?
Old May 14, 2003 | 04:29 PM
i say what i want
bump
Old May 14, 2003 | 05:05 PM
sorry it's all custom made and not all that nice, pictures make it look better...I don't even need it for my class.
I suggest getting an autopower rollcage if u are not too serious about racing, if it's all out racing then have one made but it's not going to be cheap.
Old May 14, 2003 | 05:51 PM
RacerX7fb's Avatar
paradox
Looks good What series/class are you racing in?
Old May 14, 2003 | 08:00 PM
i say what i want
i was thinking about making one in my project car. mainly to mount a camera, but partly saftely. i just wanted to see where its welded in.
Old May 14, 2003 | 09:07 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
ditto, I want to cage because a cage means your serious.
And to mount a camera. Im planning on makeing some getaway in stockholm style videos
Old May 14, 2003 | 09:51 PM
I'm going to open another thread with the camera subject...sounds like a nice idea.
Old May 15, 2003 | 11:30 AM
zaridar's Avatar
35r 13b first gen
Nice Car! What kinda speeds do you hit with it? What about0-60 time?
Coochas
44
Nov 5, 2019 11:08 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
