42mm offset - GSL-SE - Will this work?
Old Apr 28, 2003 | 12:08 AM
Chrisman1969's Avatar
Will a 42mm offset work on a gsl-se with 16x7 rims and 215/50/16?
Please help.
Thanks,
Old Apr 28, 2003 | 06:04 AM
MikeLMR's Avatar
'Last Minute' Rallying
I'm running 205/50/15's on 7" rims with a 40mm offset and the clearance to the front strut/spring mount is about 1/8" so I doubt they will fit
Mike
Old Apr 28, 2003 | 07:32 AM
Mills's Avatar
procrastination engineer
For 16" go with a 205/45. That'll keep the overall diameter closest to stock. My rims are 7.5" wide, and 215s would rub.
Old Apr 28, 2003 | 07:48 AM
I have a 40mm offset and run:16*7 with 215 40 16
and in the rear I use 225 40 16
Yokahama A520
I found all 45 series tires hit even with a rolled lip.
Old Apr 28, 2003 | 02:17 PM
Manntis's Avatar
add to cart
42mm would be pretty tight. Not tight like "Dude, your car is tiiight!" but tight like "The reason your tire blew is because the offset caused the clearance to be too tight and your sidewall got chewed up. Hope you have a speedy recovery, and I'm sorry about your car."
Old Apr 28, 2003 | 02:50 PM
fatboy7's Avatar
Got Boost?
So...... the offset he should be looking for is aroun 38-40, for 16x7 rims, and use 205/45/16's? Just curious, I hope to be looking for rims in the forseeable future.
Stock offset was 40mm on 14x6 right?
Old Apr 28, 2003 | 03:13 PM
MikeLMR's Avatar
14x5.5 is the stock size
Old Apr 28, 2003 | 03:39 PM
rollin82's Avatar
From: tucson, arizona (setting off car alarms daily) (whats a presilencer?)
not to steal a thread or get bashed either..... im looking to get 17s eventually and i was wondering what offsets i would be good with...
i sure max knows.... but any one else have some ideas
( i may get 16s dependin on how good of tires i want and rim but anyways)
thx
shaun
Old Apr 28, 2003 | 07:30 PM
rxseven's Avatar
Special Dark
So can someone here recommend what offset would work best for 7" wide rims? I am also upgrading to 15"x 7" soon and I want to use 205s in the front and 225s in the rear.
Old Apr 28, 2003 | 07:53 PM
Manntis's Avatar
add to cart
38-40 is ideal. I'm running 205/50/R16's just to provide the rims with a bit more protection and a slightly nicer ride, but 45 or 50 keeps the speedo somewhat accurate.
Old Apr 29, 2003 | 12:17 PM
Thanks guys. I decided to get some 16x7.5 with 40mm offset. I have 215/50/16's that I'm going to try, I'm just a little worried about the front rubbing......
Chris
Old Apr 29, 2003 | 05:28 PM
remydrm's Avatar
ROTARY POWER
i have 16x7 in front with 38 offset and they are damn close with 205 50. 16x8 in the rear with 215 45, these could go to 225, thats next month
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
MILOS7
Aug 19, 2015 07:25 AM
