ATF or MMO treatment?
Old Apr 27, 2003 | 07:23 PM
ioTus's Avatar
'84 5-letter
Shoud i be doing ATF in my engine, or MMO to blow out the carbon buildup?
Thanks
~Geoff
Old Apr 27, 2003 | 07:30 PM
eddierotary's Avatar
back with rotaries
dont do the ATF treatment, is really bad for the engine. try something else
Old Apr 27, 2003 | 07:34 PM
Rotary7s's Avatar
Fat chicks hurt the 7
MMO for premixing...
ATF to let the car sit for days to disolve carbon for stuck seals (hopeing)
Old Apr 27, 2003 | 07:42 PM
Sammymatik's Avatar
I'm gonna try the oil desludge stuff once I get my car running again!
Old Apr 27, 2003 | 10:46 PM
vipernicus42's Avatar
Rotoholic Moderookie
I used a bit of ATF to unseize an engine that had been sitting for 4 years.. other than that I wouldn't recommend it. Despite what I've read about it "restoring engine compression".... I just dont' trust it with all the bad stuff I've read counter it.
Jon
Old Apr 28, 2003 | 12:41 AM
Suparslinc's Avatar
It's Back!
I used ATF several times in my car; long story short I ended up having to buy a cat replacement pipe
Old Apr 28, 2003 | 12:43 AM
ioTus's Avatar
'84 5-letter
i have dual straight pipes all the way back.
Old Apr 28, 2003 | 01:06 AM
TheTwinTurboRX-7's Avatar
I was wondering the same thing
bout to make a long trip
going to replace plugs before hand
was thinking about throwing in an ATF treatment before I went
any thoughts
Old Apr 28, 2003 | 01:26 AM
Keaponlaffen's Avatar
if it ain't broke, don't fix it
for the amount of good ATF does for carbon build up, you might as well save yourself the $2 it costs. Try this: get an old rotor, or piston, and let it sit in a bucket of ATF for 2 days.... then try to clean it off... still looks pretty carboned up eh?
I would say the only thing the ATF really "works miracles" on is lubing up old, dried up, possibly rusty seals (metal ones) in an engine that has been sitting for a while.
Old Apr 28, 2003 | 01:33 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
MMO can do everything that ATF can, plus it's more combustible.
Old Apr 28, 2003 | 04:04 AM
Jeff20B's Avatar
Lapping = Fapping
I just got some MMO the other day. No ATF for me.
Old Apr 28, 2003 | 05:16 AM
inittab's Avatar
I read your email
If the engine has been running there should be little or no reason at all to ATF or MMO treat it. Your best insurance against carbon buildup is to rev the engine out on a regular basis. That will keep the carbon buildup away. But if you insist on dumping something into a running engine I would use MMO or Techron before using ATF.
Old Apr 28, 2003 | 09:08 AM
ioTus's Avatar
'84 5-letter
What would you prefer me to do, drive around w/o compression? ;-)
Old Apr 28, 2003 | 10:25 AM
inittab's Avatar
I read your email
Are you sure that your loss of compression is due to carbon buildup?
Old Apr 28, 2003 | 11:42 AM
Metallic_rock's Avatar
Ride 'n Style
If it's broke now, ATF can't hurt!!! All you're doing is loosening up the seals. That's all it's for. It's not for removing carbon build-up. At least, I've never heard of it working for that.
Just remember to replace the plugs afterwords.
Old Apr 28, 2003 | 11:44 AM
Ride 'n Style
BTW, The ATF treatment does not always work. You may have to replace the engine.
Old Apr 28, 2003 | 01:07 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
if you want to have the inside of your engine perfectly clean, the only thing that will do that is water injection. and I dont beleive water injection works on N/A engines, it just screws them up.
When the water evaporates in the engine it steam cleans everything.
Old Apr 28, 2003 | 01:27 PM
bliffle's Avatar
Since I started using MMO 6 months ago, I swear by it. Both engines run smooth, and from what I've read, the insides should be clean. Maybe it will take a while by adding 8oz to each refill, but it works and it's benign.
Never tried the ATF, but I think it's just an emergency detergent treatment for old engines. I'm hesitent to try water injection because of the corrosion possibility.
I think MMO contains a detergent that's plenty powerful to un-carb engines, and it's benign because it's a good lube.
Just my 2cents worth.
B
Old Apr 28, 2003 | 02:13 PM
Ride 'n Style
Hmm.. maybe I should try adding MMO in the gas... see what happens.
Old Apr 28, 2003 | 03:14 PM
Jeff20B's Avatar
Lapping = Fapping
That's what I'm gonna do. I suspect a little carbon is building up since I stopped driving hard (moving loads of car parts requires smooth driving and all that). It's MMO, so it'll burn lots easier than ATF.
Old Apr 28, 2003 | 03:37 PM
hamster's Avatar
the best way to burn out carbon build up is to get on the freeway and run 100 miles at 85 mph. Do this every so often and you will not have much of a carbon build up problem.
the second best way to avoid carbon build up is to start with a brand new engine and never run it.
Old Apr 28, 2003 | 04:12 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
try ATF... first... don't put too much... but that stuff smokes alot... covered my block with white smoke... then just keep adding about 5-6 oz.. of MMO every gas fill up... that's it... change the fuel filter too... gotta do that soon... your car should run better after your 10th fill up...
Old Apr 28, 2003 | 10:50 PM
ioTus's Avatar
'84 5-letter
I put MMO in it, and i'm letting it sit for 2 days.
I'm going to replace the spark plugs if i can, around here the NGK's for rx-7's cost $12 per plug. I can't afford that.
Old Apr 28, 2003 | 11:04 PM
MRGSL-SE's Avatar
you don't need too... I didn't have to replace mine after doing the atf... she fired right up
Old Apr 28, 2003 | 11:13 PM
Suparslinc's Avatar
It's Back!
Once a plug gets wet it never fires as well.
I would replace them if I could, or swap in an old set during startup if you have one.
Also, the whole thing about letting a rotor sit in a bucket of ATF is false. The thing needs the heat and compression to clean up. It's not going to magically dissolve the carbon just sitting there; it has to be blown out on the hiway a couple times. Still I don't recommend the ATF just for what it did to my cats. That stuff is obviously not meant to be put in an engine.
