Rebuild Wont Start
Old Apr 27, 2003 | 02:28 AM
MrFuzzy's Avatar
Damn Right It's Me
Unhappy Rebuild Wont Start
I just did some what of a top end rebuild on my engine took it out all the stuff. I got it back together today finally took weeks lol. When I go to start it it just spins and drains the battery. Thinking it was fuel pressure i check that and there is fuel getting to the rails. So I took the spark plugs out and noticed there is no spark. I also notices there was no fuel on the plugs before I had been flooring the pedal to try to get it to start so there shoulda been a lot of fuel on the plugs right?
I think the issue is with the ignition system what parts should i check while the car was being taken a part I had to hook the battery up to roll my window up and there was smoke and i blew some fuses. I checked the Eng Ing fuse and it seems to be ok. Any sugestions?
Old Apr 27, 2003 | 02:29 AM
MrFuzzy's Avatar
Damn Right It's Me
My car is a 87 GXL
Old Apr 27, 2003 | 02:31 AM
SonicRaT's Avatar
Super Raterhater
Check the motor fuse under the dash, then check all fuses on the driver side strut tower. Is your CAS plugged in? If you forgot to plug that in, no spark, and your injectors won't fire! If it's plugged in, check to make sure it's not loose/dirty connections/etc.
Old Apr 27, 2003 | 02:33 AM
MrFuzzy's Avatar
Damn Right It's Me
hmm that might be it I have it plugged in but its kinda suspicious
Old Apr 27, 2003 | 07:37 AM
SonicRaT's Avatar
Super Raterhater
Also you have to realize that rebuilds are NOT easy to start, check out Kevin's site (http://www.rotaryresurrection.com) Under the tech section for info about starting a rebuild.
Old Apr 27, 2003 | 10:55 PM
MrFuzzy's Avatar
Damn Right It's Me
I checked the CAS and the fuses the only fuse i have blow in the one that says room dunno what that does my radio fuse keeps blowing for some reason. Still no spark or fuel. Sadness =(.
Th0m4s
Feb 26, 2019 02:04 AM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
