help me with my 87 TII tranny, I cant get the shifter assembly apart+identifying wire
Old Apr 26, 2003 | 07:11 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
Im swapping a 91 Jspec TII into my 82 rx7
I need to swap the shifter assembly from my old tranny onto the new 87 TII tranny.
I cant get the shifter bushing off the shift rod. Is there a press fit pin or something, there was a lot of grease and **** in there so it was hard to tell
also, TII's have electric speedo senders right, there was a speedo port but no sender. or am i mistaken
also, could someone identify all the wires on this thing.
there is a large sender or switch with 4 wires and a small switch or sender with 2 wires.
please help, I need to finish the tranny by tommorow.
Old Apr 27, 2003 | 11:23 AM
come on, i have to get this part done today so I can get my motor in the car.
Old May 6, 2003 | 09:24 AM
anybody going to help me, or are you just boycotting me because I got a first gen????
Old May 6, 2003 | 10:16 AM
Icemark's Avatar
All FC trannys had mechanical speedo cables, not electric senders.
There are switchs for 5th gear, Neutral, and reverse. As I recall 5th and reverse are in the same switch assembly and neutral is on its own.
Don't know about the shifter assembly that you are trying to replace.
Old May 6, 2003 | 10:40 AM
seveninphilly's Avatar
on the road to insanity
I think there's a set of wires for the reverse lights too, right?
Old May 6, 2003 | 11:00 AM
Old May 6, 2003 | 11:15 AM
SureShot's Avatar
Seduced by the DARK SIDE
Here is a close-up of the tail end:
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
82streetracer
Aug 23, 2015 09:28 AM
