Ok guys I want to finish up the TB mod on my spare TB some questions.
Old Apr 26, 2003 | 07:10 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
ok i removed the plates and the polt thing that holds them and all the stuff that was attatched to them. Should I use JB weld to fill the holes? if not then what? I also want to port/polish it what kind of tools or techniques should I use and follow?
Old Apr 26, 2003 | 07:14 PM
AreExSeven's Avatar
Huh?
Be warned against using JB Weld. There have been stories (ie Rico05) that the weld didn't hold and sucked into the engine.
If you are going to use it, put some masking tape across the inside wall of the TB and remove that when you are done.
Personally, if I were going to plug it, I would tap and plug it, but in my case I just left the shaft in so I wouldn't have to bother (it causes very minimal resistance). I will someday go back and Tap/Plug it.
Old Apr 26, 2003 | 07:16 PM
1987RX7guy's Avatar
Tap/Plug it.
how would i do that? I heard that rico05 was actually not because of the JB weld from a friend.
Old Apr 26, 2003 | 07:20 PM
AreExSeven's Avatar
Huh?
Really? I thought thats what he said. Maybe he just thought that or something.
RETed had a great write up on how to tap/plug it on his site, but thats down now.
Just get a regular tap and find a matching plug. Aeroquip is a company that makes the plugs. They are just little threaded pieces of metal. You can probly find them at an autoparts store. Tap the whole, insert the plug and use a little thread locker to make sure it stays in place.
Old Apr 26, 2003 | 07:26 PM
1987RX7guy's Avatar
oh its like making a hole for a screw? ok autozone has that stuff.
Old Apr 26, 2003 | 07:32 PM
pengarufoo's Avatar
The mystery of the prize.
bring the TB to a local welder who has a TIG setup and experience welding aluminum.
$25 later you're ready to take a dremel to it for porting and no JB weld to get sucked into your engine.
Old Apr 26, 2003 | 08:10 PM
Amur_'s Avatar
Refined Valley Dude
Have you seen these?
http://www.rx7turbo.com/tbmod.htm
http://www.rx7turboturbo.com/robrobinette/polish.htm
Old Apr 26, 2003 | 08:15 PM
1987RX7guy's Avatar
thanks amur_
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
