acv - too many hyrdocarbons - failed emissions !!! help
Old Apr 25, 2003 | 11:40 AM
i went to get my car inspected the other day and i failed emissions testing, blowing out too many hydro carbrons... i looked around the forum and people say its the acv and stuff like that
what else should i do?
where is the ACV, where can i buy a new one/rebuild/fix it????
thanks
Old Apr 25, 2003 | 11:53 AM
Rotary13B1's Avatar
Yeah, The AVC is a large component of the exhaust system. From what I understand, it routes fresh air to the cats to produce cleaner fumes. (non technical babble)... When mine was bad, I could smell gas from the back, I happened to borrow one from a buddy of mine to pass smog tests here.... and the fumes were clean as warm air.
ohh yeahh... the ACV is pretty damn expensive, try borrowing one form someone.. b/c it's about $300 from mazdatrix new!!
Old Apr 25, 2003 | 02:35 PM
APT CSVT's Avatar
I took the ACV off my GSL-SE. I can check if I still have it lying around. Dunno if it is in any better shape than yours as we don't have to pass emissions tests in MI.
Aaron
Old Apr 25, 2003 | 04:21 PM
thorin's Avatar
but what exactly is an ACV? is it a pump? a hose? a screw? a filter?
Old Apr 25, 2003 | 05:18 PM
APT CSVT's Avatar
Air Control Valve. It either takes air from or puts extra air into the exhaust.
Here are two pictures I just took of mine. It looks like this and goes where the gold plate is here. Comes off with a 10mm wrench, but helpes to remove the air intake tube temporarily.
Old Apr 25, 2003 | 06:34 PM
BRealistic's Avatar
So if you smell gas from your exhuast, even when cold, it is because the ACV is bad?????
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
RedBaronII
Sep 20, 2015 11:29 AM
