Can I Remove the Flapper at the Charge Control Valve?
Old Apr 25, 2003 | 10:28 AM
vudoodoodoo's Avatar
I did Rikki's non-seq mod. I been only getting 8psi.
And I keep hearing this tap noise at idle.
Could be the reason why I'm not getting enough boost or at least the reason for the tap noise....
Old Apr 25, 2003 | 02:18 PM
spurvo's Avatar
don't race, don't need to
can't you just wire it open?
Old Apr 25, 2003 | 02:49 PM
Can I? Hmmm..
Old Apr 25, 2003 | 03:47 PM
spurvo's Avatar
I was only thinking wire it to make sure that is the problem. If it really was, would it not be easier to pull the Y-pipe, split them apart, and remove the valve?
Old Apr 25, 2003 | 05:57 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Fd3BOOST's Avatar
Yup, i did .. make sure to remove the actuator and cap off the lines also.
[IMG]]http://www.nopistons.com/forums/uploads/post-10-1050887599.jpg[/IMG]
Old Apr 25, 2003 | 08:25 PM
Th0m4s
Feb 26, 2019 02:04 AM
msilvia
28
Apr 14, 2016 12:58 PM
highspeedrider
Sep 8, 2015 07:55 PM
